07-26-2011, 12:17 AM | #1 |
help..
so i bought some 2inch drop spindles on ebay they say they are for 60-87 chevy trucks and say they just need 73-up upper ball joints and 73-up outer tie rods..sooo i pick them up i have a 70 c10 with 72 disc brakes on it my calipers and rotors swapped in and i swapped the upper ball joints and put the outer tie rods in... problems i am having...
-lower a arm is hitting my wheel and so is the outer tie rod perch -outter tie rod has bigger threads than the older style adjuster sleeve basically what do i need to do to make this work? inner outer tie rods adjuster sleeves and a centerlink? lower a arms??? |
07-26-2011, 12:23 AM | #2 |
Re: help..
ps will 75 3/4 ton suspension swap over minus spindels and stuff? sway bar a arms steering and such?
07-26-2011, 05:41 AM | #3 |
Re: help..
On the tie rod adjuster, I would give CPP a call. They have billet aluminum ones to adapt just about anything to anything and they look/work way better. They helped me out with a similar issue.
67 5.3L Build |
07-26-2011, 11:38 AM | #4 |
Old Skool Club
Re: help..
This seems to be the problem with suppliers like that. I'm not dissing you for what you bought, but it makes me happy to know that what I bought from ECE was all designed to work with OEM stuff.
But, swapping parts and making stuff work is what hot rodding is all about...and always has been.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
