1) What do i need to clean up engine for paint (i know brake cleaner)
2) Also, my right exhaust manifold has a small crack, (going to trash it) what tools do i need to remove exhaust manifolds to prep for paint? (heard horror stories about bolts breaking off) 3) planning on using engine spray bombs, (no painting tools) Thanks for any advice. Posted via Mobile Device |
Re: clean it up? engine
1) Brake cleaner is expensive and messy. I prefer a cheap purple power or similar degreaser to remove the bulk of the nonsense. Then, follow it up with a spray bottle filled with mineral spirits paint thinner. This will remove filmy, oily residue left behind. Now the surface should be ready to paint.
2) I can't think of any special tools needed to remove exhaust manifolds, just be careful. Like anything, don't speed through this process with ill fitting sockets or you could find yourself in a crap situation. On that note, you may need a special tool to re-install your exhaust manifolds. They are undoubtedly warped from years of use so the holes may not line up properly requiring the use of a exhaust manifold spreader. You can rent this part from autozone or o'reilly's. No need to purchase it unless you see yourself needing it often. 3) Now you will get differing opinions on how to paint an engine. I have painted 4 or 5 so I'm no expert, but I have found a combination that lasts longer than others. Clean the block thoroughly as mentioned before, tap and mask accordingly, use a high temp primer first. Go for 100% coverage with the primer which may be two coats. Let dry, and follow up w/ 2-3 coats of high temp engine paint. Take your time when applying paint. It's a building process so first coat will be light and look like crap, the second coat will be about 80% coverage, and the final coat 100%. Again, this is how I do it, and it holds up well over time. If you want to show it to people, then do it right. I find myself popping my hood a lot because my engine bay is more attractive than my truck. LOL Hope this helps. ![]() ![]() ![]() |
Those are sweet! Thanks for the great advice.
Nice job man. I'm getting ready to yank my motor and trans to replacing all my gaskets and seals so this'll be tons of help.
How many miles are on your engine? What's prompting the gasket swap? Any reason you wouldn't want to have it rebuilt for a little more?
"Brake cleaner is expensive and messy. I prefer a cheap purple power or similar degreaser to remove the bulk of the nonsense. Then, follow it up with a spray bottle filled with mineral spirits paint thinner. This will remove filmy, oily residue left behind. Now the surface should be ready to paint."
I second that motion! I used Simple Green in the one gallon concentrated form to cut the grease and grime. Then went back over the engine with mineral spirits in a spray bottle and used lots of blue shop towels. Stay away from the red rags, they leave a bunch of fuzz. |
If you have lots of caked on piles of grime, whether it be an engine, trans, diff, suspension parts or whatever, cheap oven cleaner fron the dollar store works great. For parts you don't mind getting wet, follow up with a pressure washer and watch the grime and paint come right off. Not sure that I would use the pressure washer on an engine that's not going to be torn down completely though.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
#8 | |
78K & 79C Jimmys
i just use engine shampoos
pressure washer at a local bay(neigbours might get upset washing my gunk down the street/drain) the manifold bolts have broken for me ,leaving a nib and i used a oxy/acel torch from inside the exhaust port to cherry heat it and that did it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#10 | |
