Old 07-27-2011, 02:27 PM   #1
jwa76fleetside
jwa76fleetside's Avatar
cab corners
i need to replace my cab corners and well as some of the cab floor on my 76 c10....has anyone ordered from LMC and done this repair? any advice? (can you write a little step by step if possible....)
Plus LMC sells inner cab corners, outer cab corners, and outer cab corner full? can anyone tell me what the differences are here?
-JW
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 07-27-2011, 03:28 PM   #2
juiceman650
juiceman650's Avatar
Re: cab corners
I recently ordered a rocker panel, full outer cab corner, and an inner cab corner. They are in pretty good condition. The difference between those three corners is that the INNER cab corner, is practically the inner portion that's under the truck/in your cab that you can't really see. The cab corner is just the corner, and the FULL or EXTENDED cab corner is the corner, plus some extra length, width, and height.
juiceman650 is offline   Reply With Quote
Old 07-27-2011, 05:13 PM   #3
jwa76fleetside
Re: cab corners
ahah.....that helps. if you could grab some pics of your repair along the way? id love to see them and hear how it goes
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 07-27-2011, 10:31 PM   #4
xs-style
xs-style's Avatar
Re: cab corners
http://67-72chevytrucks.com/vboard/s...corners&page=5
Heres a post from Kieth Seymore in his re-build thread. It has some good step by steps, and some info on panel adhesive.
1978 Scottsdale - celebrating 10 years of teaching me profanity
1990 Silverado - bought in Nov. 2016 and it's already catching up - Sold
1987 k5 blazer - sold... :\ seed money for the 81
1981 k20 4x4 - 5.3 swap in progress
Events attended:
Spring GOG 2011
Dale JR car show Summer 2012
Gathering at Tommys pickup parts
xs-style is offline   Reply With Quote
Old 07-28-2011, 01:44 AM   #5
juiceman650
Unhappy Re: cab corners
I'll try to man, repairs won't happen for a while though. Still need a new bed and door. (i was T-boned)
Old 07-28-2011, 12:56 PM   #6
jwa76fleetside
Re: cab corners
that link helped to see......i think i will weld vs adhesive though.
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 07-28-2011, 01:05 PM   #7
Rons86
Rons86's Avatar
Re: cab corners
I put LMC cab corners on my truck. Just outers, all of the inner sheet metal was good. I did not take pictures though. They worked out pretty well. The part inside the door is the hardest part to get right, took some metal shaping. the rear of the cab corner does not match the existing cab perfectly also. Other than that they worked out well. Was a lot easier that I thought it would be. I just butt welded mine, but you could roll a lip for a stronger weld.
Rons86 is offline   Reply With Quote
Old 07-28-2011, 07:36 PM   #8
Chlsnk
Chlsnk's Avatar
Re: cab corners
They are just as good of parts as any but be a pal and order from one of the fourm vendors that allow us keep us posting here.
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
