#226 |
So Many Ideas, So Little Money
Re: Project...praise the lowered
congrats man!
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu ![]() Marshalltown, Iowa |
#227 |
yeah congradulations!! fine looking lady and very cool to see she helps you out with the truck!!
'71 GMC pickup; "Ashley," ![]() |
#228 |
VA72C10
![]() Join Date: Mar 2008
congrats and cool pics!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#229 |
67cheby
![]() Join Date: Sep 2008
well done!! on the wife and dad's project ...i assume ??
#230 |
![]() Join Date: Aug 2010
Congrats man! I'm married to the love of my life as well, and couldn't be happier! Heck, she even bought me my truck! And I had her out helping me a couple weekends ago. Gotcha a keeper there for sure!
Raymond 1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper. My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594 The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939 Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402 |
#231 |
congrats man!
#232 |
'85 Stepside
![]() Join Date: Jan 2006
congrats!!
#233 |
thanks y all.she is a keeper for sure and that is my dads project.sorry for no updates but im still picking away at the small tedious stuff.so since the last update i almost have the wiring complete.computer, relay box and fuse box`s are all mounted and tucked away under the dash and under the new console.cab mounts are made and tacked im place.i slimmed down the fuel tank re welded it and hydro test it.its now installed and i just have to figure which line went where in the sending unit.spent hours getting the new style brake booster installed where it could be tucked against the new steering shaft with out the joints rubbing.what a pain in the a$$.the sierra brake pedal is now slimmed down and installed.the sierra gas pedal assembly is hacked up and installed with the cable hooked up.rear window with the new rubber is installed.door rubbers are glued in place.i started to cut and shape the sierra carpet in place.and i did some shopping.i think i now have everything for my airbags.and picked up some 4" exhaust pipe for the side exit.i think thats it.
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 Last edited by (joey); 08-01-2011 at 08:10 PM. |
#234 |
Kvn1011
wow i just read every page and post!! very nice build love the custom touches!! subscribed!!
#235 |
![]() Join Date: Jul 2011
Love the dash and console man. Your doing great I'll be checking in.
Master welder I've got a degree in metalfusionology
#236 |
good progress man! You'll be on the road in no time!!!
#237 |
reading every post from start to finish must have taken for ever.glad to have new followers to keep me picking away.and i really hope it is on the road soon.the snow flys so early up here.it would be nice to put some miles on it.a quick update.more part ordered,more body work done to the hood and more parts bought.almost forgot wind shield is now in and brake lines to brake booster are cut flared.hope to hit it hard this weekend.
check out my build (the start of a shaved,channeled,bagged 67 gmc with a 01 gmc frame and drivetrain) http://67-72chevytrucks.com/vboard/s...d.php?t=434253 |
#238 |
a quick update from this weekend.friday night i trimmed more carpet and shaped it to fit on drivers and pass side.saturday morning i hooked more wires up,ran my e brake cables into the cab.they will fit up perfect to the hand brake lever.did some more door adjusting,figured out where im going to install the 4 point harness,installed the gas tank for the final time,hooked up all fuel lines to the sending unit.today i dumped in some fuel and flashed the beast up.sounded mean with the straight pipes but with some sensors unplugged and intake just stuck on it ran rough.but it did run.i also extended some wires to the brake booster and wired up the wiper motor.finished installing my front flex lines to my brakes and cut flared and installed the new brake lines.then i drilled all my holes fro running my air lines and installed grommets.it was a ton of small boring stuff but its just more off the list.heres a vid showing its now alive.
#239 |
Sounds bad a$$!!
#240 |
Very cool man. i love that sound!
Cam 1972 Chevy C/10 "Custom Cruiser Project" Build Thread 1961 Olds Super 88 (Daily) 1966 Chevy Corvair 500, "Marigold" SOLD 2005 Subaru Outback Wagon DEAD 2008 Pontiac G8, New Winter/Daily |
#241 | |
-- 1969 Chevy Build: http://67-72chevytrucks.com/vboard/s...d.php?t=461209 Quote:
The front: 17x7 245/45/17 Kumho Ecsta XS The Rear: 17x11 315/35/17 Kumho Ecsta XS |
#242 |
in person it sounds so mean.i like it so much im going to order a couple exhaust cutouts.should be fun on cruse nights.as for the floor in not sure how much it ended up being.i just made sure it was more then enough to drop over the newer style frame.today i got my steel cut and bent for boxing in the front frame horn notches.made a filler neck and e brake cable mounts.nothing exciting but at least its some progress
#243 |
Cutouts are awesome! Make it even better and put electric cutouts on the ends! That way you can have that sound whenever you want it at the flip of a switch! I think Summit and Jegs have kits with everything you'd need. Ever see Trucks tv show the "copperhead" build?
#244 |
i just read all of this thread in the last hour or so!! i just want to say you have done an awesome job at blending the two cabs! congrats on beening married, wait til you have kids then you'll think this is your last project, lol!!! i like how you saved the cab and repaired the rust good job really good job!! any updates yet??
#245 | |
#246 | |
#247 |
well i had a short break at the cottage last weekend and went back at it.last week i shortened the drive shaft,brought out my camber and tightened the front end,trimmed down the front bag mounts and installed front air bags,ran all my air lines,did some seam sealing on the front clip,installed my 4 point harness,welded the pass side seat back so it has more forward lean when all the way up,and some more small boring stuff.since we are getting more rain today im going to my buddy's place to do some more work to the box sides and good.i havnt taken any pics lately but if any of you want to see what any thing looks like or how i did something just let me know and i can get some.
#248 |
Nice build. Looks great. I am surprised, with the console and new gauge cluster that you didn't modify the glove box to match, like a gen 1 Vette or Impala style. The symmetry would rock.
#249 |
did you have to order wheel with a certain backspace to get it to work or did everything go together ok with certain mods. Always wanted to put my 73 on a newer frame just curious
#250 |
i was going to do something with the glove box but the dash was taking way longer then what i wanted.i will do the glove box during round 2 when i go through and change and mod stuff i missed in a couple years.
