07-28-2011, 12:40 AM | #1 |
Hate this shtuff
Went to primos house bout twenty minutes away
Coming home engine got so hot blew new upper radiator Hose Fresh rebuild whats going on help help Posted via Mobile Device
WITNESS Dont be like me be better than me Last edited by redmonster; 07-28-2011 at 12:45 AM. Reason: .. |
07-28-2011, 12:51 AM | #2 |
Re: Hate this shtuff
Sounds like an air pocket in the motor; prevents the coolant from circulating properly. Raise the front end high as possible and run the motor till it heats up, be careful though; once the thermostat opens and that air heads out it'll push a ton of HOT antifreeze out as well! I've had to do this a couple times.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
07-28-2011, 01:37 AM | #3 |
Remove the thermostat and Drill a tiny hole in it to allow trapped air to escape and allow the coolant to contact the thermostat and open it.
07-28-2011, 06:40 AM | #4 |
can b lots of things/wrong direction water pump/bad or incorrectly installed thermostat/collapsed lower radiator hose/ a leaky connection not enough coolant/incorrectly installed intake or head gaskets/ bad timing adjustment/rad fan not working properly
those are all fairly common problems
07-28-2011, 01:49 PM | #5 |
Plus, rebuilt engines running a bit hotter than ones that are broken because of all the surfaces that are establishing a wear pattern. If you have an EGT sensor, you can really tell when the rings seat themselves. The EGT temp will drop like a rock.
07-28-2011, 01:52 PM | #6 |
It's all in the timing
1st thing I would do is change the thermostat.
The Dude Abides. ---------------------- I aint sayin, I'm just sayin. |
07-28-2011, 09:25 PM | #7 |
its all about the +6 inches
did it over heat and blow the hose, or are you assuming it overheated before the hose popped?
07-29-2011, 12:48 AM | #8 | ||
"I ain't nobody, dork."
Are you runnin' the 40 year old stock original radiator as well?
Gary
07-29-2011, 01:26 PM | #9 |
Gary yes the radiator is original but before it went in was acid washed
Posted via Mobile Device Longhorn man the upper and lower radiator hoses were brand new after the rebuild When going one the road sounded like a boiling kettle look at temp gauge was way over h so shut it off popped open hood and bam a small hole in the upper hose Why did u ask
WITNESS Dont be like me be better than me |
07-29-2011, 01:32 PM | #10 |
Took out thermostat replaced hose still running hot y y y
07-29-2011, 02:18 PM | #11 | |||
Longhornman was basically stating that if you didn't notice the overheat before the hose popped... there might be other damage. Gary
07-29-2011, 03:13 PM | #12 |
Who's got steelies?
His engine may well be overheating, but it shouldn't blow a hose (especially a new one) because of the pressure relief on the radiator cap, which no one has mentioned yet. Try a new stat & rad cap, and make sure you get all the air burped out of the cooling system.
1969 C10 LWB W/ 250 I6 & 3spd 1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver. 1975 Chevelle Malibu Classic Coupe 350/th350 mint green 1970 C20 Suburban 350/700R4 4.10 gearing green & white 1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver 1983 GMC 1500 Sierra 305/SM465 2.73 rear end How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
07-31-2011, 02:44 AM | #13 |
Would u guys suggest getting a new radiator for the 250 I6 didnt even make it to the store
Bout quarter mile now the drive belt busted Help Help Help Posted via Mobile Device
