#151 | |
Re: 1954 Chevy / S10
Shannon |
#152 | |
Shannon |
#153 | |
Shannon |
#154 |
#155 | |
Shannon |
#156 | |
Shannon |
#157 |
BlueJeep, Here are some more pictures. The first picture is the piece that I beadrolled. The second picture is the edge shot. The third picture is with it cut down to about 3/4". The forth picture is where I cut out the bad and the fifth picture is with some cheap primer on it so it does not rust. It has been a 100 degrees here for a couple days and today we finally got rain.
Shannon |
#158 |
Certified Car Nut
You the man Shannon, you the man.
#159 |
Thanks for the additional detail! When I finish mine out (I already welded it) I plan to match the profile of the doors as best I can.
Now that I know what a pain that seam is, I check them out at shows. Most I see are half filled with paint and half not, and I just wonder how much water seeps in there and stays wet....
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
#160 |
Kabwe, Thank you
BlueJeep, No problem on the pictures. If anybody ever needs more pictures just ask. I know what you mean about that seam. I think that welding it up helps to seal it better so hopefully it will not get water behind it and then rust. When I did it I took out both of the returned lips out and the whole back of the cab is now all one. There was not any rust back behind it except a little surface rust up in the inner cab panel. Shannon |
#161 |
Im diggin' all the great fab work! Very cool stuff!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#162 |
kustombrad, Thank you . I am hoping that that gets ride of some of my buddies rust problems.
Shannon |
#163 |
![]() Join Date: Mar 2005
I can't believe that I've missed this thread. I am blown away at your fab skills. You do very nice work! I am really impressed at your enthusiasm to tear into stuff that most guys run away from. I won't overlook this thread again!
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
#164 |
chevyrestoguy, Thank you very much. My buddy bought the 48 truck and blasted it and was surprised at the rust and I told him that almost anything can be fixed. I was never afraid of tearing into anything and learn alot from just doing it. I was on your thread earlier and I am in the same boat as you on the car show thing and not having mine finish. I am hoping to aleast have my panel at least driveable next year.
Shannon |
#165 |
![]() Join Date: Mar 2011
Shannon, computors been in the shop since Monday, see you've been busy, nice job....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#166 |
oldman3, Thank you. Yes I have been busy. I have a little more to do I my buddies truck cab and then back onto the 54. Computers are great till they stop working. Glad your back. Any new projects?
Shannon |
#167 |
No new projects, just helping my son with a 50 F**D coupe.
#168 |
Can you give some pointers on shaving the hood seam?
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
#169 |
Fat Mike. The way I did it on my panel was just welded the seam and then was going to fill the valley with filler BUT I thought about it and am going to redo it when I get back to working on it. I think with the way the hoods are the filler will crack. So when I did the 1954 I sheared a strip and welded it in. Which I would not do again because the double thickness of the hood makes it not easy the hammer and dolly the hood now. So with learning as you always do, I would shear out a 1 inch wide strip and I would start at the back of the hood and use a slitter wheel the cut out a 1 inch wide strip out of the hood about half way down the hood(where the valley is). Then weld in the strip skipping around . Then you do not have the double thickness. Then work from where you left off and work to where the valley stops. I think trying to do it in 1 piece would be a pain. I would just weld the seam in the front. Then I would grind BOTH sides of the hood that way you could hammer and dolly it and make it flat again because it will warp a little. I am going to redo mine that way. After seeing Kabwe's hood and a couple other 55-59 hood being pancaked (slant section), I want to do maybe a 1 or 1 1/2 inch pancake on mine too.
On another note we got a new addition to our family. This is 8 week old Bailey, a chocolate lab. My 3 kids just love him. |
#170 |
Shannon, great looking pup, what did the kids name it? Ref the hood, I welded mine together and filled with filler. No cracks in 8 yrs, but when the hood get hot from driving you can see the line in the center until it cools down. Your ideal is great, lots of work by great.....Jim
#171 |
oldman3, We named him Bailey. I wondered if it would crack and that worried me. If I would have filled it, I would have used fiberglass stranded or all metal first for the strength. It is good that yours did not crack. Never thought about the different expansion thing in the sun.
Shannon |
#172 |
Thank you for the info!
#173 |
Fat Mike, No problem. I never mind sharing any info because this is a great site and there are a lot of great people on here.
Shannon |
#174 |
X2 on that.....Jim (yeah I used the short fiberglass filler)
#175 |
Certified Car Nut
Hey thats a great looking pup. I love dogs but a lot of guys on here know that already so I will not bore you.lol
