Old 07-29-2011, 11:41 PM   #1
mas09ts
mas09ts's Avatar
Question External Voltage Regulator to Internal
I just Installed a new alternator on my truck and had to change the plug for an internally regulated alternator, so I was wondering if i wired it up correctly.
The White wire on the plug is connected to the blue wire originally in the harness.
The Red wire on the plug is a jumper from the main power on the back of the alternator.
So the black, and white wire that went to the alternator originally is useless(thats the part im not sure about.
Then on the old voltage regular plug, connect the Blue and Brown wires.
Have I done this right, thanks in advance guys.
Mitch
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 07-30-2011, 12:55 AM   #2
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Re: External Voltage Regulator to Internal
HERE is the the thread in FAQs on it.
If it doesn't look like your wiring, shout it out
and someone will send you to the electrical gurus.
Wiring works on any later model internal alt, tmk
ETsC10 is offline   Reply With Quote
Old 07-30-2011, 01:05 AM   #3
mas09ts
mas09ts's Avatar
Thanks, yeah mine is just like that so it should be fine.
Mitch
22yrs. Young
Old 07-30-2011, 01:27 AM   #4
fixit-p
fixit-p's Avatar
The way you have it wired will work but if you want to get the most efficient system don't just jump the # 2 wire to the back of the alt. instead run it to the regulator plug and connect it to the red wire. What this does is it allows the alternator to sense voltage remotely instead of at the back of the alt. This is important because that red wire is connected to the main alternator buss that feeds the cab and battery and is where you will have the biggest voltage drop. Here is a diagram below how I like to jump the wires, the colors don't matter whats important is that the red wire goes to # 2 and the brown wire to # 1 terminals.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 07-30-2011, 02:26 AM   #5
mas09ts
mas09ts's Avatar
So all i need to do is connect the jumper wire to the red wire on the voltage regulator instead?
Mitch
22yrs. Young
Old 07-30-2011, 08:37 AM   #6
stich626
ok me try this
red to blue
brown to black
stich626 is offline   Reply With Quote
