Old 07-30-2011, 09:53 PM   #1
amodedude1
amodedude1's Avatar
SRW to DRW 14 bolt
First off, sorry for all the questions lately, but the more I know, the more I can help in the future. We all start somewhere?
My question is, can you convert a SRW k20 4x4 with a 14 bolt FF rear to a dual rear wheel truck?
The axles are the same between the 3/4 dually and 4x4, they are both 14bolt FF. I'm not sure if they are the same width. If not what is the difference, and if I wanted to do the conversion what would need to be done? Thanks!
amodedude1 is offline   Reply With Quote
Old 07-30-2011, 10:50 PM   #2
88bagedntaged
88bagedntaged's Avatar
Re: SRW to DRW 14 bolt
Hey, I went through the same thing, I havea 88 CC that was a SRW and now its DRW. Here in is the problem. From the reasaerch I did, the width and all is for the most aprt the same. However the drums are different and it take a whole lot of work to comvert them over. Even if you had the other axle, I really thought about using the adapters that convert it, but there is a 3 inch aluminum spacer that is holding what ever weight your pulling or hauling. Not something I trust. It weas a whole lot easier finding a dually rear end on CL and swapping it out. Here are pics for ya !
88bagedntaged is offline   Reply With Quote
Old 07-30-2011, 11:00 PM   #3
rjn72
rjn72's Avatar
drw rearends are narrower than srw rearends. I looked into converting mine to srw for looks, but it wasn't worth the effort for my gain.
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline   Reply With Quote
Old 07-31-2011, 12:04 AM   #4
russgt
russgt's Avatar
You will need to get a dana 60 for the front, I dont think that you can get DRW hubs for a dana 44 or 10 bolt. Pick up some DRW hubs and brakes from a different 14 bolt or pick up a 1 ton axle and move the spring perches to match your 3/4 ton frame. You should be able to get a good deal on the DRW parts as most people go the oposite direction and turn the duallys into SRW trucks.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 12-28-2012, 11:26 PM   #5
1955 mancave
1955 mancave's Avatar
not trying to steal the thread, but if i have a 14 bolt srw and i have a 14 bolt drw how hard would it be to convert the srw to drw both are complete so i have the parts, i just want to make sure that it can be done.
thanks.
1964 1 Ton flatbed service truck (sold)
1964 C-10 panel (project complete frame up build)
1957 210 post pearl orange
1955 mancave is offline   Reply With Quote
Old 12-29-2012, 12:46 AM   #6
comegetsome2003
comegetsome2003's Avatar
If the axles are both out of square body trucks you can just bolt the DRW axle under a SRW truck without any mods.....my dually has a SRW axle under it because it was shorter to get the semi wheels tucked under the fenders.....im running 4 semis out back so i just have the thickness of the adaptors on my studs.....if i would have run a 16 inch inner wheel and adaptor then i woulda had to install longer studs
comegetsome2003 is offline   Reply With Quote
Old 12-29-2012, 10:26 AM   #7
hatzie
Moderator
hatzie's Avatar
Are there 14bolt DRW axles?
I thought the duallys were Dana 70 axles.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-29-2012, 10:44 AM   #8
1955 mancave
yes there are plenty of 14 bolt DRW rearends around, Dana is prob one of the most brand recognized rear ends, and they are also very strong, that being said that may be why you thought that. hey i'm far from an expert but the more i'm on here the more i learn from these guys.
Old 12-29-2012, 10:49 AM   #9
1955 mancave
well i have drw on the truck now but i dont like the gear, so i have located a srw with the gears i want so i want to convert that srw to drw so i dont have to pull the gears out and have to mess with setting up the back lash and gear mesh pattern.
Old 12-29-2012, 11:00 AM   #10
80SPORT
80SPORT's Avatar
Dually pickups use the wide Dana 70 rear axle
Dually cab and chassis use the GM 14 bolt rear axle
The rear spring perches on k10/k20 are wider apart than K30;if you want to dually a K20 you will need to change hangers or move perches
K10/K20 use corp 10 bolt or Dana 44;K30 uses Dana 60 in front;all will bolt in as an assembly
80SPORT is offline   Reply With Quote
Old 12-29-2012, 10:07 PM   #11
Rubble
Ya I just went thru the reverse last winter,converted a DRW to single and swapped diffs. The dually was a Dana 70 & went to a 14 bolt semi. Had to remove the dually spring hangers and swap for K 25 hangers.Lot of work,probably should have just moved perches instead,but I work cheap!!!
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 12-30-2012, 01:45 PM   #12
hatzie
Moderator
hatzie's Avatar
Never looked at a C&C... No wonder I thought they were all Dana 70s.
