08-02-2011, 02:30 PM | #1 |
Help me ID my Rear-end.... for drum brake rebuild
hey all, im flipping thru my lmc truck mag, but the rear end id in here pretty much only seems to id DANA rear ends. i need to order new drum hardware, but i of course have to know what im running to do so. any help would be appreciated. thanks!
08-02-2011, 03:29 PM | #2 |
Six in a row makes it go...
Re: Help me ID my Rear-end.... for drum brake rebuild
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
08-02-2011, 03:29 PM | #3 |
The Older Generation
You don't give a guy much info to go by but I'm guessing you have a 3/4 or 1 ton. If so the 3/4 would be the Eaton Corporate or HO52 rear axle. If it is a 1 ton it would have the HO72. Good luck finding parts for it. You might be able to find some of the smaller stuff but if you need drums you will have to find some good used ones... LockDoc
08-02-2011, 04:17 PM | #4 |
Old Skool Club
Look on the right axle tube, on the top of it, and you should find a group of letters and/or numbers.
Also, what does your SPID (if it is still in the truck) say? I only count 10 bolts. According to some of my reference materials....it's quite possible that it is just that...a 10-bolt. Since I see coil springs, you don't have a 1-ton.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
08-02-2011, 04:21 PM | #5 |
Looks like an HO52 in a Chevy C20 to me. Can't be a 1 ton since it has coils and it's not a Dana or a 12 bolt.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
08-02-2011, 05:34 PM | #6 |
BUT disc conversions are availabe.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-02-2011, 10:34 PM | #7 |
its all about the +6 inches
its not a ten bolt, it is the corperate/eaton HO52. Most parts stores list dana or non dana.
08-03-2011, 07:09 PM | #8 |
1969 Custom 30 wrecker
I got new drums for my 71 C20 with the same rear from either Autozone or Advance auto for about $108 each a few years ago.
They aren't available for the 1 tons that I could find, I looked for my wrecker project.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
08-03-2011, 07:35 PM | #9 |
What?
Being that it is a 2wd, you should be able to source all drum brake hardware from any good parts house.
I got spring kits, shoes, and wheel cylinders from my local Napa store. Drums are another story, and may take time to find.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
08-04-2011, 01:08 PM | #10 |
If your drums are in good shape you can have them turned. My local NAPA turned my fronts for $10 each.
