Old 08-05-2011, 02:38 AM   #1
wannagettachevy
wannagettachevy's Avatar
brakes issue
i know this is probly an easy fix but i thought ide ask here first. i got in my truck the other day after sitting for 2 weeks with the parking brake on and the brake pedal sank almost all the way to the floor. only the last 8th of a push did anything. the truck did stop, but very abruptly and it didnt seem right at all. i only drove down my street about 50 feet. there was no issues when i parked it 2 weeks ago. the truck has manual drum brakes. i would really appreciate any help because i love drivin my chevy!
wannagettachevy is offline   Reply With Quote
Old 08-05-2011, 02:46 AM   #2
losthope
losthope's Avatar
Re: brakes issue
i would check the master and see how much fluid you have in it, also look around the back of the drums and junction blocks for any fluid leaking from anywhere and make sure all fittings are tight, look around where the master cylinder bolts to the firewall,and also underdash in cab for fluid if master is leaking and needs repair or replaced, id suggest trying to pump the pedal and seeing if it pumps up, sounds like your getting air in the lines somewhere.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 08-06-2011, 04:34 AM   #3
vgnope
vgnope's Avatar
Re: brakes issue
With all I can think of, losthope already covered..
vgnope is offline   Reply With Quote
Old 08-06-2011, 07:35 AM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: brakes issue
For less than $30 at most parts stores, I'd replace it.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 08-06-2011, 01:33 PM   #5
wannagettachevy
Re: brakes issue
a master cylinder is only $30?
Old 08-06-2011, 01:36 PM   #6
wannagettachevy
Re: brakes issue
thanks for the help guys, ill try that stuff and let you know how it goes. i tried pumping and didnt get anything. so are we calling this a master cylinder problem? what else would be the problem?
Old 08-06-2011, 02:13 PM   #7
kieth
kieth's Avatar
Re: brakes issue
Wheel cyclinder.....
kieth is offline   Reply With Quote
Old 08-06-2011, 02:15 PM   #8
61_FL_Apache
Who Me?
Re: brakes issue
It was at Advanced Auto Parts store.
Steve
2001 Blazer 4D 2WD
Old 08-07-2011, 10:50 PM   #9
losthope
losthope's Avatar
Re: brakes issue
in the above post i said to look at back of drums to see if there is any fluid because of wheel cylinders or bleeder screws,sometimes you have to pull the drums and physically see whats going on and if they are leaking inside....
Timmy D.
