Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-19-2011, 10:32 PM   #1
68_Shortbox
68_Shortbox's Avatar
Project First Car '68 Shortbox Fleetside
Hi, I'm finaly starting my build thread for my '68 shortbox. I bought this truck March of 2010 and it's my first car. I plan on making a decent driver out of it. I'am not expecting it to be perfect at all, just a nice looking daily driver. So far my dad and I have have done some brake, exhaust work, and a bunch of little things to make it safer to drive. Currently we have the motor pulled so we can change the clutch, paint the motor, change engine seals, and paint the front of the frame. We also have to fix a crack in the frame where the power steering box is. This spring/early summer we will be swapping the '70 cab and front clip for a '68 cab and clip. The '68 truck that we will be using is a factory big block, air conditioned, and bucket seat truck. My '68 already has a disk brake conversion from a '71 suburban. My truck is a custom, it currently has a 327 out of a '68 impala and a truck 4 speed. I'am thinking about painting it blue with the grill painted black. I'am also considering painting a black hockey stick stripe like some of the '69 camaros had on the side. Thanks for looking and I will try and keep this thread updated as I work on the truck.
Build thread for my SWB 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=447938
1968 Chevy K/10 short box fleetside (my project)
1969 Chevy Z/28 Camaro (my dad's project)
1968 Chevy C/20 long box fleetside (parts truck)
68_Shortbox is offline   Reply With Quote
Old 02-19-2011, 10:47 PM   #2
68_Shortbox
Re: Project First Car '68 Shortbox Fleetside
Some more pictures of it this summer and some of the way it is now.
Old 02-20-2011, 05:42 AM   #3
67chevy1series
67chevy1series's Avatar
what color are you gonna paint it? you gonna keep the 70 nose or give it that slant hood! hahah the 68 front clip? stock? custom?
67chevy1series is offline   Reply With Quote
Old 02-20-2011, 12:02 PM   #4
too much stuff
Roadtrip!
too much stuff's Avatar
Glad to see you are working on it!
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 02-20-2011, 12:06 PM   #5
Patsfan34
Patsfan34's Avatar
Awesome man, enjoy it!
Patsfan34 is offline   Reply With Quote
Old 02-20-2011, 06:18 PM   #6
68_Shortbox
I'm thinking about painting it Le Mans Blue, Marina Blue, or Cortez Silver with the '68 grill painted black. I'm going to put the '68 cab and front clip on it. It will be alittle of both (stock and custom) so I guess you could call it a very mild custom. I will either get or make a hood scoop and I'm thinking about putting some SS emblems on it but that is still in questioning. I'm trying to use photoshop to make a mock up of it.
Old 02-20-2011, 06:24 PM   #7
68_Shortbox
I'am too, but it's a real bummer not driving it. But atleast it will look better and it will be safer to drive.
Thanks.
Old 03-22-2011, 07:54 PM   #8
MikeJones16
MikeJones16's Avatar
Where Can i order that Air cleaner?
MikeJones16 is offline   Reply With Quote
Old 03-23-2011, 01:41 AM   #9
68_Shortbox
LMC is where I got mine and it was reasonably priced too.
Old 03-23-2011, 01:46 AM   #10
68_Shortbox
I'm still working on cleaning up the frame rails and engine. For my birthday my parents bought me a factory tilt steering column from a 72 chevy. It is slightly damaged but it should be fixable.
Old 04-21-2011, 09:29 PM   #11
68_Shortbox
I painted the motor last night. I still have more engine parts and the frame to paint. I still have to fix the crack in the frame and do some brake line work. I will try to get some pictures of the motor up tonight.
Old 04-27-2011, 12:27 AM   #12
68_Shortbox
Old 04-27-2011, 12:40 AM   #13
mstrav1973
mstrav1973's Avatar
Just as quick thought, those tall valve covers might not fit. Do you have a body lift on the truck? It seems some trucks they fit some dont, just thought I would throw that out there before you tried sliding it in without confirming you have the clearance.
Matt
72 chevy k-10, swb, auto, 35's, rally's, posi, 4" lift, 2.5" old style 40 series flows with headers and crossover pipe and some other stuff!!
mstrav1973 is offline   Reply With Quote
Old 04-27-2011, 11:16 PM   #14
68_Shortbox
Matt
It has 4in. blocks in the rear and a extra leaf spring on each side in the front. I can't see anything that they would hit. Thanks for the warning I will have to make sure they fit.
Old 04-28-2011, 04:52 AM   #15
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
I think he's referring to the valve covers hitting the fire wall. With a body lift it would help space the engine away from the body.
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 07-18-2011, 11:00 PM   #16
68_Shortbox
Its been awhile since I've done a update so here its goes. I jacked my truck to take the wheels of so I could clean up the rims and my dad noticed that the u-joints were worn out. So we tore the hubs apart on the passenger side and replaced the u-joint and put in new bearings and seals in the hub. We also painted up the hub housing, caliper, and part of the axle tube on the passenger side and put a new rotor and brake pads on. We still have to do the same thing on the driver's side but we are gonna do that when we get it back together. We are almost done with welding the crack in the frame and will hopefully have that done soon. We still have to paint the front of the frame and do some more brake work. I'm hoping to get the frame painted in a couple days.
Old 07-21-2011, 10:38 PM   #17
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
Looks good.
Just take your time and do it right.
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
Old 07-24-2011, 04:36 AM   #18
68_Shortbox
Originally Posted by Conroe trucker View Post
Looks good.
Thanks! We are definitely taking our time haha.
Old 07-24-2011, 04:39 AM   #19
68_Shortbox
Its been too hot out to work on it this past week. I did get some of the paint stripped off of the frame and will hopefully get the front of it painted soon.
Old 07-24-2011, 09:19 AM   #20
silver7
silver7's Avatar
Nice progress 68 shortbox. Glad to see another of these fine trucks are getting the attention they deserved. Looking forward to seeing this come together.
Shawn
1971 C10 4x4
silver7 is offline   Reply With Quote
Old 07-24-2011, 05:19 PM   #21
68_Shortbox
Thanks! I can't wait to drive it again its been way too long.
Old 07-25-2011, 03:13 AM   #22
67chevy1series
engine and front axle look really really good! keep it up!
Old 07-25-2011, 04:27 AM   #23
68_Shortbox
Thank you!
Old 08-05-2011, 05:35 AM   #24
68_Shortbox
I decided that it would be easier to pull the front clip off and paint the front of the frame. I got all but two of the bolts out that hold the front clip on and I disconnected the wiring. If everything goes as planned we will pull the clip off today. While the clip is off we might just go ahead and do the cab swap too. I'm also considering taking the 4in. lift out and bringing it back down to stock ride height.
Old 08-05-2011, 11:54 PM   #25
68_Shortbox
With the help of my dad, brother, and a friend we got the front clip off. It wasn't as heavy as we thought it would be. I will try to get some pictures up soon.
