Old 08-05-2011, 09:16 AM   #1
jbgroby
jbgroby's Avatar
Tricks to getting door aligned
Got the door hung and I'm trying to get them set right. This is what I came up with. I mounted the dovetail and I have the door closed, with the help of a friend or two. holding the door closed, I'll lossen the bolts a little and slide/wiggle/shove/cuss and tap the door in place (I hope) .
How did you guys get it done?
Jake
jbgroby is offline   Reply With Quote
Old 08-05-2011, 09:43 AM   #2
LeftCoast32
Custom Builder
LeftCoast32's Avatar
Re: Tricks to getting door aligned
Jake
I use paint sticks tapped to the edges of the door jam to get it mounted at first. Then do final tweaks to align it perfect.
LeftCoast32 is offline   Reply With Quote
Old 08-05-2011, 01:06 PM   #3
steverino66
I like to put a hydraulic floor jack with a 2x4 on it under the back/bottom end of the door (door slightly open/balanced on the jack) with the door hinges bolted mostly snug, then fine-tune adjust using the jack - saves some grunting and cussing. The paint stick trick is great for checking consistent gaps all around.
steverino66 is offline   Reply With Quote
Old 08-05-2011, 09:35 PM   #4
jbgroby
jbgroby's Avatar
I'll try the paint sticks as I'd not like to smash the fingers. Thanks
