Old 07-23-2011, 08:35 PM   #1
motobrua
Question Rare chassis cab truck...NEED INFO!
Hi, my dad and i already have a '67 lwb c10 that we're restoring. We needed a parts truck and so today we picked up another '67 c10 that didnt have a bed which we assumed somebody had just taken it off, but after running the vin number and doing some research it turns out its a chassis cab truck that they only made 39 of in 1967. Should we restore it or just use it for parts? Any help would be appreciated.
1967 c/10 lwb about to have a built 468 bbc/m22 "rockcrusher" combo dropped in
http://67-72chevytrucks.com/vboard/s...d.php?t=448814 our build post
motobrua is offline   Reply With Quote
Old 07-23-2011, 08:51 PM   #2
litew8
litew8's Avatar
Re: Rare chassis cab truck...NEED INFO!
Do you know why they only made 39 of them?
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 07-23-2011, 08:54 PM   #3
litew8
litew8's Avatar
I did a quick search (on the net) and somebody comment this:
"A truck built as a chassis cab has a different frame than a pickup. A pickup bed won't fit on a chassis cab frame, and neither will 5th wheel rails."
And wikipedia says:
"A chassis cab or cab chassis is a body style, and type of vehicle construction, often found in medium duty truck commercial vehicles.
Instead of supplying the customer with a factory pre-assembled flatbed, cargo container, or other equipment - the customer is given the vehicle with just 'chassis' rails and a 'cab'. This allows the customer to assemble any desired aftermarket equipment; for instance, fire apparatus, an ambulance, or a recreational vehicle conversion package; which can be customised for the specific needs of the customer.
Aftermarket equippers, including coachbuilders, often make their own packages that can be ordered for the truck."
... so I'm not sure, maybe that's why there isn't a bed on it already.
It might be worth more money to somebody doing a special restore of some of the above mentioned vehicles.
I'm sure there's someone more knowledgeable here that can help explain further.
Old 07-23-2011, 09:08 PM   #4
motobrua
Some more info on the truck: we live in iowa and this truck has always been in iowa so it was a farm truck because nobody around here would have any other purpose for a chassis cab, also do you know exactly what the auxiliary springs option did?
Old 07-23-2011, 09:09 PM   #5
motobrua
And i did not see you were from Iowa as well...small world lol
Old 07-23-2011, 09:18 PM   #6
litew8
litew8's Avatar
yep, small world indeed.
The auxillary springs were used for supporting heavy loads. They would only really help when the truck was loaded to its max. capacity. There's a leaf like spring that connected from the frame to the axle (I believe). When the load hit its max. capacity - the spring would help support. It did add like 500lbs more capacity to the GVW Range though, for each side - so a 1 ton truck would be a 2 ton?? Not sure the specs - someone else can correct me.
It sounds like a good match for that frame, if its intended use was for Ambulances, etc...
You can see the auxillary spring mount in a pic in my build post.
Someone took the springs off mine though, prob. rusted away.
See the bar bending downward going near the tire:
Maybe the truck was a left over from a dealer in town, who didn't sell it or something. Or whoever bought it - didn't convert it to whatever.
Or maybe they stripped it down, took whatever was on it off the back.
Old 07-23-2011, 09:32 PM   #7
motobrua
we have the original owners manuals and all the dealership info is there...maybe we could find out some more info from them if they are still in business
Old 07-23-2011, 09:37 PM   #8
litew8
litew8's Avatar
Worth a try!
source: IMCDB.org
source: IMDB.org
Old 07-23-2011, 09:38 PM   #9
no moa
no moa's Avatar
My half ton parts short fleet truck has those Helpers on it!
1972 C10 Deluxe.Shortbed. 402/400. A/C, white interior, needs complete restore. Project Red, white and blue. Used to be a Longbed apperently.
http://67-72chevytrucks.com/vboard/s...d.php?t=451950
1971 c10 step 250 3 OTT
1969 c30 TOW-MATER. 307 4 speed, holmes 440 body.
http://67-72chevytrucks.com/vboard/s...d.php?t=451082
2006 CTS-V LS2 6spd.
no moa is offline   Reply With Quote
Old 07-23-2011, 09:40 PM   #10
motobrua
Our owners manual had the original owner's name in it and i looked up the gentleman and he did a couple years ago but his obituary said he ran a furniture store and a funeral home/ambulance service...but my dad and i think it was probably just a furniture delivery truck or something along those lines
Old 07-23-2011, 09:55 PM   #11
litew8
litew8's Avatar
Yes, possibly just a panel truck - or could have been a flatbed - used to haul coffins/sofas around.
Not sure about the ambulance I pictured above - the cab might be a different structure? no idea
If it were a flatbed, the wood probably rotted away a long time ago and someone just stripped it bare. (guess)
Old 07-23-2011, 10:08 PM   #12
71swb4x4
71swb4x4's Avatar
A half-ton cab and chassis truck is probably really rare, I didn't know they built the 1/2 ton that way. Rare doesn't always equal valuable. I don't think you would get anyone to pay a premium on a "rare" half-ton cab and chassis unless it was in beautiful shape. Unfortunately as that truck sits it is probably more valuable as parts.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-23-2011, 10:25 PM   #13
litew8
litew8's Avatar
Old 07-23-2011, 10:39 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
Old 08-03-2011, 05:34 PM   #15
motobrua
Thanks for all the help...we got it totally stripped and will probably begin chopping it up for our other '67
Old 08-03-2011, 09:19 PM   #16
litew8
litew8's Avatar
are you going to post a build thread for the 67?
Old 08-04-2011, 01:31 AM   #17
motobrua
Already have one...i added it to my signature
Old 08-04-2011, 09:28 PM   #18
Street Smart
Street Smart's Avatar
good luck with the truck, father/son projects are the best!
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 08-04-2011, 09:49 PM   #19
6 Door King
If you cut it up or part it out, try to leave the chassis stock. If you were to sell it for parts, the odd and more rare parts will be what the buyer is seeking. If you have the room, tuck it away and advertise what you have, a buyer will find you eventually.
1954 3100 Nova Subframe, Pontiac Posi, roller for now1967 C-10 SWB 350/350/Posi. Soon to be Crew Cab!
1978 Crew Cab Dually roller
1982 C-30 Rollback, 454, 4 speed
2004 K1500 Suburban Z71 5.3 Kid Mover
6 Door King is offline   Reply With Quote
Old 08-04-2011, 10:05 PM   #20
71swb4x4
71swb4x4's Avatar
Depending on the wheel base the chassis may be nothing more than a LWB. Once everything is stripped off it's just another 67 LWB chassis.
Old 08-05-2011, 05:26 PM   #21
Joesjunk
Joesjunk's Avatar
Do you have a pic of the glove box sticker? Interesting truck...
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
chassis cab, rare
