#176 |
![]() Join Date: Aug 2005
Re: Project: NO-LIFE,...
Looks great!
#177 |
Nice progress
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#178 |
Good to know on the Brothers floor covering - as I have thought about getting one before - Love the Red carpet - so it all works out
72 Cheyenne shorty "CheyLow" 72 3/4 long 4X4 69 SWB "Prospector" 68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled" ![]() ![]() |
#179 |
big guy
![]() Join Date: Jun 2008
Keith
Looking really nice my friend, I love the red carpet adds a touch of class! Ray |
#180 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
It is an exact replica of the original floor mat. It will be going in my stepside.
#181 | |
Hope you are doing good. Any new projects???
#182 |
I worked most of the day and didn't make much progress.
I cleaned the grease covered trans crossmember and painted it. Removed an exhaust hanger and found out the doughnut gasket at the manifold is shot. Started to install the TH350. I have ALOT of distance between the new converter and the original powerglide 153 tooth flexplate. (3/8"-1/2",... just guessing,... but that's too much) So I dropped the trans back out. I'm not sure what's going on. I checked NAPA's websited and they show a 168 tooth flexplate for $87,... so I'm going to try that. (that means a new starter) I bought an assortment of moulding clips to fix a few pieces of loose trim. Got the upper tailgate and one lower trim piece secured,... but I got the wrong clips for the upper bed side mouldings. Gotta make another order now.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-07-2011 at 10:29 PM. |
#183 |
Still Learning
That crossmember turned out great. So, what's the deal the powerglide takes a different flexplate? I didn't know that. Keep up the hard work.
#184 | |
The grease was an inch thick on that thing. I get sidetracked with painting sometimes,... when it doesn't really matter. The powerglide takes a smaller flexplate. NAPA only carries the 168 tooth 14" flexplate for the 292. I have a stock SBC flexplate,... but it won't work. The 292 has 1/2" crank bolts. (SBC has 7/16") Plus the 292 flexplate has 3 locating dowels,... the SBC has only 1.
#185 | |
What size nutserts did you use?
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 08-07-2011 at 11:06 PM. |
#186 | |
(the drilled hole size it a little bigger than 1/2") Plenty of room for my incorrect drilling. Ha. Plus you can use some old "washer head" fender bolts to hold it in.
#187 |
VA72C10
![]() Join Date: Mar 2008
very nice work on the interior!!!
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#188 | |
Did I mention that was on both the spindle side & rotor side. Yesterday it was the th400 (including the inside the bellhousing where the input shaft is) ![]()
#189 |
Sweet - I will check it out. Thanks again
#190 | |
I watch the clock, and wonder where the day went. (that's where a giant blast cabinet would come in handy) My TH350 needs a repaint. These tranny shops think rattle can over the 3 layers already on there, will be good enough. I decided to not repaint it. I'm going to pull the 292 someday for a rebuild. (I'll detail the tranny then) Right now I just want to get it "road worthy".
#191 |
Village Idiot....
Great progress! You'll be happy you went through all this pain once you get behind the wheel.......
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
#192 | |
Tot Roddin'
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#193 |
The carpet looks great!
'68 SWB Fleetside '98 K1500 Silverado |
#194 | ||
'69 Chevy SWB
![]() Join Date: Feb 2009
![]() Keith, I'm jealous!! Both your truck are what I strive for when I'm finished with mine. I'm just too limited on garage space. Keep up the great work.
Matt ![]() ![]() ![]() ![]() ![]() '69 Chevy SWB Fleet, Primer Black; Project No Name '06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold '08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!! '99 Dodge Dakota R/T, Intense Blue; DD, Sold Quote:
#195 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#196 |
![]() Join Date: Sep 2004
Dont let him fool you guys. He says paint looks bad but I think its perfect. Ive been to his place before to buy a bed for buddys truck and got to ogle and drool all his trucks and stuff. Paint on no life has perfect patina.
Good progress Keith, trucks looking awesome.
Daily-94 K2500 350 5spd extended cab longbox Project Red Velvet-68 C20 396-th400-AC-PS-PB-all original except for the 8 track and the gun rack. Build thread>>>>http://67-72chevytrucks.com/vboard/s...d.php?t=495881 My 01 TA and 88 Formula hide in the garage. :-) |
#197 |
Tot Roddin'
![]() The truck looks good. ![]()
#198 |
Small update.
My new TH350 is finally in. Had to buy a new flexplate and starter to make this work with my 292. Also my new flexplate only had the "big" converter bolt pattern. I had purchased a stock converter with my new trans. The TH350 converters have the "small" pattern. Lucky for me,... the guys at the trans shop swapped it out for a TH400 converter with the big pattern. If you need a transmission in central Missouri,... check out these guys. (http://mandmtransmission.com/) Spent last night hooking up all the little things. Today I installed the radiator, hoses, pulley, fan, belts and the fan shroud. (does anyone know if the 292 trucks had a 6-cylinder specific fan shroud?) Doesn't sound like much,... but it was a long day. Also bent up a new modulator vacuum line. (The 5' stick of 1/4" steel line was about 2" short. Ha.) I wish I had time to paint the engine up nice,... but I'm trying to get this truck running for the Kansas Goodguys event at the end of the month. I think all the steel lines would look better, if they were black. Here's a few pics,...
#199 |
Tot Roddin'
Lookin' good Keith!
Once KS is over, I agree with you, the lines will look good in black.
#200 |
Village Idiot....
Detail the motor and the lines will look right at home......
