Old 08-08-2011, 12:21 AM   #1
jeromio
Tail light fuel filler door?
I want to put a tank in the spare tire area. I don't want to put the filler in the bed. I searched quite a bit here and didn't turn up any pics or info on anyone doing a fuel filler door in a tail light of a 60-66 SWB truck. I did see the pics in hte 67-72 board, but those tail lights are quite a bit different. So, anyone pulled this off? Any advice before I try this?
jeromio is offline   Reply With Quote
Old 08-08-2011, 12:26 AM   #2
losthope
losthope's Avatar
Re: Tail light fuel filler door?
you should read the whole thread its a good one, but its a burb but i like the gas/tail light idea......on page 2
http://67-72chevytrucks.com/vboard/s...ghlight=blazer
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 08-08-2011, 10:20 AM   #3
Northern lights
My '64 short fleet had the filler behind the tail light when I got it. The light wasn't hinged but rather, it had thumb screws that you removed and just pulled the light assembly out. It could be that mine was just poorly plumbed but, with the plumbing going down the post, then having to go horizontal between the bed and frame to get to the tank, you had to spoon feed the fuel in. It was a HORRIBLE setup. I removed the whole thing and put the tank back behind the seat where it belongs.
Northern lights is offline   Reply With Quote
Old 08-08-2011, 11:44 PM   #4
jocko
jocko's Avatar
seems a fray of electrical wires hanging at the fuel inlet might not be in the best interest of the driver. I'm just sayin. The factory setups had the wiring well separated from the filler pipe. I'd be cautious and make sure there is no conflict, i.e route wiring carefully and it would be a really slick setup.
Old 08-10-2011, 09:32 PM   #5
mater63
mater63's Avatar
i just finished my 63 with the filler neck hidden in the drivers tail light i took a filler neck out of a cougar(because it's smaller diameter and takes a smaller cap) & got a gas door off a chevy I removed the outer skin and attached the taillight to it then fabbed the rest of the inner fender under the light to close it up try to post pictures later i haven't had any trouble putting gas in it will take it as fast as i can pump it
click on seales restoration for some pictures
mater63 is offline   Reply With Quote
Old 08-11-2011, 04:56 PM   #6
MailManX2
MailManX2's Avatar
Mater, that's exactly what I want to do to my 60 Apache..
Ken B
60 Chevy Apache
2019 Chevy Silverado Z71
Why buy something when you can build it for twice the price..
Just because something can be done doesn't mean it should be done...
MailManX2 is offline   Reply With Quote
