08-10-2011, 12:54 PM | #1 |
stiffest lowering springs?
who makes the stiffest lowering springs on the market?
08-10-2011, 01:26 PM | #2 |
Re: stiffest lowering springs?
ACME has the stiffest I believe.
J/K. I'm not sure. I'm assuming your talking coil springs. I think they will all be about the same. If I was guessing I would say Eibach probably had the most performance oriented springs. Everyone I know that has had a set has really enjoyed them.
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar Dropped and LS Swapped SWB 87 Build Thread |
08-10-2011, 01:27 PM | #3 | |
08-10-2011, 01:36 PM | #4 |
I bought a set of McGaugheys and they were horrible, way too soft. Truck bounced like a super ball. Bought a new set of stock springs, cut 1 coil, problem solved.
08-10-2011, 01:41 PM | #5 |
i have stock springs right now, ive ridden in a 88-98 on eibachs and it was pretty stiff, are they about the same spring rates as the 73-87 springs?
08-10-2011, 03:42 PM | #6 |
At the body shop.
I cut two coils off a set of 1ton springs. Very stiff wasnt harsh.
" That didnt make it any newer " " Dont antique the equipment " |
08-10-2011, 04:38 PM | #7 |
were they taller than c10 springs before you cut them?
08-10-2011, 04:52 PM | #8 |
You could move your spring bracket back to use 1 ton springs.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] 1999 k3500 crew cab dually 6.5tdi/4l80e |
08-10-2011, 11:19 PM | #9 |
At the body shop.
A bit. I liked the ride height. It came out like a 4" and 6 with flip out back. Handled like a slot car.
08-10-2011, 11:38 PM | #10 |
I have 2" DJM springs on mine..and they are far too mushy for my tastes. I'd stick the stocks back in after some cutting, but I don't feel like busting the front end apart again.
08-11-2011, 12:02 AM | #11 |
What model designation was the 1 ton? C30? That way I know both ways of saying it when I go part hunting
08-11-2011, 02:22 AM | #12 |
At the body shop.
It started as Cab/chassis turned into tow truck.
