08-11-2011, 08:43 PM | #26 | |
Re: The Circuit Rider ... Has an Engine Miss and Water Leak???
The Hot Dog...I could never attend one of WES's events out in Washington so I said he could at least send me a hot dog via UPS. He did and its the rubber Hot Dog. I have an HEI set up. I have been on the road this week so I haven't had an opportunity to check anything out. Water...only during the rain storm. I will not let a little water and engine miss get this kid down. I hope to post some info about the winners of the meet tonite. I will pm you my email address. Again it was great meeting up with you.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-12-2011, 12:28 AM | #27 |
Project Junkie! Fishing Poor!!
Bad ju-ju..... Well I will let you know my hotdogs are tested ju-ju free!!
DeWayne, try running a bead of windshield sealant under the gasket where it meets the windshield frame. I have a ju-ju free feeling that the water is getting past the gasket where your door pillars meet the upper and lower windshield frame. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
08-12-2011, 12:50 AM | #28 |
Master Procrastinator
I have run into the miss issue with the coil severay times, brand new coil not performing correctly, the spring and rubber underneath were installed incorrectly, the same miss with a vaccum line cracked, worn cam lobe, fuel filters as the previous owner didn't realize the factory q jet has the little filter on the carb so they had installed a second inline on the frame and both were marginal, and a faulty electric choke that was stuck open, all worth checking easiest to hardest, as for the water, I have run into this with a poor window seal, good luck with the truck
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
08-12-2011, 01:34 AM | #29 |
Windshield leak is no big deal; there's factory drainage engineered into these trucks-drain holes at the base of the w/shield pillars meant to track down and out the rockers. I'd bet the waters coming in at the top corners; the joint of the w/shield pillars and upper cab header-a good gooping will fix 'er up! If your miss is under load, I'd look for a weak spark plug/burnt plug wire; weak spark will fire until cylinder pressure increases=load.
1972 factory 2 Wheel Drive Blazer-Sold 1972 K10 4X4-Sold 1971 Chevrolet Cheyenne/10-Sold 1970 Chevrolet C/10-Sold 1968 GMC 4X4-Project 1968 Chevrolet C/10 Pro Street 1970 GMC 3/4 Ton-Parts 1997 2WD 2DR Yukon-Sweet http://67-72chevytrucks.com/vboard/s...d.php?t=335664 |
