08-11-2011, 10:53 PM | #251 |
Re: Tommys66 Build
[QUOTE=QWYKTRUK;4839468]You do nice work. That engine bay looks real clean!
thanks, That's what I was going for.
I love the smell of lead paint! |
01-08-2012, 05:28 AM | #252 |
Hey Y'all!!
Re: Tommys66 Build
Any updates Tommy?
Just hopin' I live long enough to finish something!!! |
01-08-2012, 01:05 PM | #253 |
Re: Tommys66 Build
Nothing at the moment, I havn't touched it since september, been busy with side jobs, but I will be making some progress soon hopefully.
03-20-2012, 10:34 PM | #254 |
Re: Tommys66 Build
Ive been trying to get my brakes lined out, but cant get any petal. I have bleed them every way possible. I tried using a vacuum pump, tried using a oil can to pump fluid from fitting back to master, tried the two person method(one pumping petal one bleeding), I had bench bled the master cylinder before I started to what I thought was good. I am at a loss here.
Any Ideas?
03-20-2012, 11:00 PM | #255 |
Re: Tommys66 Build
I would re-think using only a frame mounted cooler for your trans. You'll be hard pressed to find a trans builder who will ever recommend using that type of cooler only. Most want you to use the trans cooler in your radiator...why? Because water will transfer and remove far more heat than any air cooled version, not to mention bringing your trans to operating temp quicker on cold days. And, as posted by another forum member, you have little to no air flow in that location. Just my .02..been doing this for 30 years...learned the hard way. |
03-21-2012, 09:30 AM | #256 |
Re: Tommys66 Build
I know what you mean I never get to work on my own stuff because I am always working on other peoples stuff but it does fund my projects
03-22-2012, 11:47 PM | #257 | |
Re: Tommys66 Build
03-23-2012, 12:03 AM | #258 |
Re: Tommys66 Build
I installed an electric fan and aluminum fan shroud from jegs. Fan is controled from the PCM. It was 80deg in the shop today and the fan cycles on for very little time to maintain temperature at an idle.
03-23-2012, 12:09 AM | #259 |
Re: Tommys66 Build
Still no luck on the brakes. Im using dot 5 fluid and have read that it is very tedious to bleed correctly. So, maybe I still just have air in the system, if so, I don't know how to bleed this fluid properly.
03-23-2012, 01:51 AM | #260 |
60-66 Nut
Re: Tommys66 Build
Do you have brakes on either front or rear, or none at all?
03-23-2012, 02:24 AM | #261 |
Re: Tommys66 Build
Got fluid at all wheels, can see the calipers tighten up when petal is pressed, the petal will go all the way to the floor with little resistance when truck is started. With truck off, you can pump the petal and it gets firm and will hold pressure.
04-02-2012, 10:13 PM | #262 |
Re: Tommys66 Build
brakes are fixed! I moved the push rod on the brake petal from the top hole, which was straight in line with the booster, to a hole about 2 inches further down on the petal. Doing so, puts the push rod at an angle, giving the brake petal less leverage, and now feels right.
04-02-2012, 10:21 PM | #263 |
Re: Tommys66 Build
So, I was out in front of my shop mocking up my fuel filler neck on the bed from my parts truck, had been messing with it for a while and couldn't really come up with anything, so I stepped back to think a minute and looked to my left and this is what I saw chilling out beside me! Two copperheads! within just a few feet of me!
04-02-2012, 10:58 PM | #264 |
Senior Enthusiast
Re: Tommys66 Build
Yikes!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
04-03-2012, 10:05 AM | #265 |
Daring to be Different
Re: Tommys66 Build
That would have freaked me out.
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
09-06-2012, 10:27 PM | #266 |
Re: Tommys66 Build
Installed a vintage air genII compact system. all works except the heater control valve will not close. Only thing i can figure is the valve is bad, or the lever control isnt functioning properly. everything else on the system functions correctly.
09-07-2012, 07:17 PM | #267 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: Tommys66 Build
Very nice build!!!
You can tell that you have a passion for this, and are not cutting any corners. I just read the entire build to get caught-up, but I have a few questions... I really like that color, what is it used on?...Do you have a code? I am not sure from the photo's, but won't your pan-hard bar hit the frame long before your rear axle is up into the c-notch? Will you run a risk of the fuel boiling in the fuel-rails by not running a return line to the tank, and constantly recirculating the fuel? Do you think that your transmission fluid will heat up running back and forth over your exhaust that close to the header collector? just a couple things to consider, or look into. |
09-09-2012, 03:42 AM | #268 | |
Re: Tommys66 Build
10-18-2012, 04:28 PM | #269 |
Re: Tommys66 Build
I just read you entire build, looking good! may have some questions for you once i start my ls swap!
01-28-2014, 01:02 AM | #270 |
Re: Tommys66 Build
any plans for emergency brake cables? (I was looking at yours for reference on how you routed them with your trans cross member so I could copy )
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
01-29-2014, 05:14 PM | #271 |
Re: Tommys66 Build
Any Updates???
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
03-02-2014, 01:57 AM | #272 |
Re: Tommys66 Build
No recent progress...I plan to modify the factory e-brake setup by mounting the ebrake crossmember upside-down on the trans cross member. If that don't pan out, i will use a pinion mount brake setup.
03-02-2014, 11:14 AM | #273 |
1 thing at a time is progress.
Re: Tommys66 Build
Man it is looking great!
Alan
Philippians 2:14-16 |
09-09-2014, 12:35 PM | #274 |
Re: Tommys66 Build
This is a top notch build. Love the detail in this one so far. Can't wait to see the finished product.
James
'64 C10 Build Officially LQ/NV3500 swapped and Bagged |
09-09-2014, 09:20 PM | #275 |
Re: Tommys66 Build
Really? no new posts in two years...My guess is it has died, or someone else has purchased it that is not on this forum...
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
