#26 |
Re: 56 Chev Garage build
#27 |
#28 |
Certified Car Nut
Hey Man,
I just checking in and seeing what you've been up to. BTW I like the steering wheel also. |
#29 |
#30 |
Today cut out the inside fender wheels to clear MK II A Arms and took all that crappy tar stuff that the factory gets crazy with! All that is left is to weld up unessary holes and a little body work
#31 |
Looking good.
Kim |
#32 |
#33 |
A320 Pilot/USAF Retired
Nice work, love the steering wheel too!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#34 |
Finished install sway bar, welded my home-made brackets
#35 |
Cleaned up all that tar crap factory sprays on inside floor and primed today
#36 |
Primed found a couple of Pin holes on toe boards easy fix
#37 |
The floor came out real nice.
Kim |
#38 |
#39 |
Nice work! Are you going to put down some sound deadner?
#40 |
Yes,after I paint the floor boards and firewall with white rustoleum easy to see for us old farts when trying to do wiring job. I am going to roll the paint on only because who ever looks under the carpet and it will be a smoother surface for deadnor to stick. Oh by the way left the pmel world at Edwards now back on the Raptor.
#41 |
I decided to fab up a brake cable today with original cable and a sleeve that I had laying around from my Model A Ford that I sold. I also had to fab brakets to mount the 56 Chevy handle. I cut the handle down and welded back up because I did not like the lenght of original and the way it sticks down in the Cab. Here are some pics.
#42 |
This is what it looks like all bolted up.
#43 |
Must have started something my neighbor has a new project too.
#44 |
Very nice and I will now copy that cause I was trying to figure out what to do. Thank you very much!
#45 |
#46 |
Get him on the site.
#47 |
Nice work Dude! That a great idea with the e-brake! I've got a couple of bud's at Edwards.
#48 |
#49 |
Nice work. That steering wheel looks right at home in your truck. Wish I had the $$$ to buy one of those "shrunken" wheels for my truck but priorities are elsewhere for now.
I did something similar to your emergency brake setup using cables from Control Cables. I used part of the original rod and brought the cable up through the original hole. I made the cable holder out of a piece of pipe cut at an angle. It works good. |
#50 |
For today Fab up some rear bumper brackets for a chrome stock rear bumper. Knothing fancy just use 3/8 Plate and a borrowed plasma cutter and press at the Base Auto Hobby Shop where I work (Edwards AFB). And no I don't own a shop and I wont make anymore to much work! Thank You
