Old 08-13-2011, 08:02 PM   #1
5150
C10 Club Tennessee
5150's Avatar
How much cut on bottom cup
I know on 67-72's the bottom cup can be 5/8 inches tall. What about on the 73-87's?
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 08-13-2011, 08:14 PM   #2
hotrodhomi
hotrodhomi's Avatar
Re: How much cut on bottom cup
I have square body A arms on my blazer and I set the cup in the arm and measured how much I could cut off without rubbing.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 08-13-2011, 08:19 PM   #3
mongoose
mongoose's Avatar
mine are 2 inches and they're close to the one side already. that's with 2600's something smaller you might be able to cut it some.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 08-13-2011, 08:48 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
I thought it was 1-5/8" total height.
Keith
Convert to disc brakes.
Old 08-14-2011, 12:50 PM   #5
5150
C10 Club Tennessee
5150's Avatar
The reason I ask, and I pretty much knew I screwed up, was that my dumba$$ cut the cup to a TOTAL of 5/8 inch not a 5/8 inch off the original cup.
Bryan
www.gmtruckshow.com
Old 08-14-2011, 01:37 PM   #6
hotrodhomi
hotrodhomi's Avatar
no problem, it's just metal. You can weld it and cut it again. That's the beauty of metal. You can cut it three times and still be too short, but then you can weld it to make it longer.
'66 impala ht
Old 08-14-2011, 02:43 PM   #7
jimmydean
jimmydean's Avatar
Measure once, cut a couple times, weld on some more, then measure and cut it right?
Sounds like a long process, but it would work.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-14-2011, 05:37 PM   #8
5150
C10 Club Tennessee
5150's Avatar
So have we decided on what Keith thinks, no shorter then 1 5/8? I can buy these:
http://*******************/bag-bracke...t-circle-lower
and just flip the other pieces over and weld them on. Just want to make sure the 1 5/8 is correct.
Bryan
www.gmtruckshow.com
Old 08-14-2011, 07:35 PM   #9
lolife99
lolife99's Avatar
Bryan.
Make a cardboard template.
Easy to cut with scissors and correct any errors.
Then you will know for sure.
Keith
Old 08-14-2011, 08:20 PM   #10
5150
C10 Club Tennessee
5150's Avatar
I'm confused Keith, I just need to know the minimum height on the bottom cup.
Bryan
www.gmtruckshow.com
Old 08-14-2011, 08:31 PM   #11
lolife99
lolife99's Avatar
Cardboard circle.
(like a halo)
1-5/8" tall.
Make sure that is tall or short enough before you cut the actual cup.
Keith
Old 08-14-2011, 08:56 PM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
1 5/8" in my experience, too. That said, I would use a template to be 100% sure...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-15-2011, 08:18 AM   #13
5150
C10 Club Tennessee
5150's Avatar
Bryan
www.gmtruckshow.com
Old 08-18-2011, 09:52 PM   #14
tcb-1
Nothing to see here.....
tcb-1's Avatar
1 5/8" here as well.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
