Old 08-15-2011, 10:14 AM   #1
Thealien
Thealien's Avatar
Need a couple of measurements please
I need to know the size of the antennae hole where the antennae wire passes into the cab.
What size are the rocker plug holes?
I need to get a couple of blind plugs for the holes and want to have them before I start taking things apart.
I was unable to get the hard rocker plugs installed so I am going to use a rubber blind plug but need to know what size they are. Can't really get in there to get a good measurement.
Mark
Old 08-15-2011, 12:16 PM   #2
1972k5blazer
Re: Need a couple of measurements please
The antenna hole is right at 9/16 in , The hole in the front of the rocker is right at 1in and if you needed them the holes in the bottom of rocker boxes are right at 3/4in . Hope this helped you
1972k5blazer is offline   Reply With Quote
Old 08-15-2011, 12:40 PM   #3
Thealien
Thealien's Avatar
First two are what I needed, could have sworn the antennea hole was bigger?
Thank you
