08-15-2011, 08:53 PM | #1 |
HELP with alt bracket please
I have a 350 and my alt goes on the pass side I have purchase a bracket bu I cant seem to make it fit. I know dah!!!!!!!!! It cant be this hard can any one help. Im sending pics but there a little blurry Thanks Jeff
08-15-2011, 10:59 PM | #2 |
Senior Enthusiast
Re: HELP with alt bracket please
Don’t know if this will help, but years ago I had a similar style on my 350. The pictures in the attached thread show how it mounted.
http://67-72chevytrucks.com/vboard/s...rnator+bracket In the text I mention slotting the rear hole in the bracket to fit the manifold, but looking at the pictures again I realize I did that because the engine was running a Summers Brothers gear drive, which moved all the accessories forward ¼”. The mounting plate is visible behind the water pump and timing cover. |
08-15-2011, 11:13 PM | #3 |
http://www.google.com/search?q=chevy...w=1223&bih=606
See if you can fine something here, click on the pics for the info
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
08-16-2011, 12:56 AM | #4 |
60-66 Nut
Sometimes you will need a spacer where it bolts to the boss on the water pump. You may also need to slot the holes to be able to bolt it up.
08-16-2011, 09:03 PM | #5 |
looks like yours bolts in a different spot on water pump but might have to do the same thing i did here with the spacer.
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
08-17-2011, 07:11 AM | #6 |
UCA63
I'm thinking that bracket is for a long style water pump.
You may also have to backspace at the adjustable mounting point to get it to line up properly ? T
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
08-17-2011, 11:32 AM | #7 |
the water pump i have pictured is a long pump and i still had to space it....jfyi
08-17-2011, 11:48 AM | #8 |
The chrome ones I have gotten for my truck really don't line up well at all. I have tried two brands for the same application and they were vastly different in shape. Then add the intake variances and it can be a headache. Ended up having to bend the last one to square it up and space both water pump and intake. Going to take the factory stuff it had on it and get it powder coated.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
08-17-2011, 11:25 PM | #9 |
there are actually two different top alternator brackets for the long water pump the 69 to 75 models and the 76 to 86 year models they both look very similar but when you put them side by side you can easily see the difference in off set and rear mounting point...hope this helps http://cgi.ebay.com/ebaymotors/ALTER...item27bd88c31f and http://cgi.ebay.com/ebaymotors/ALTER...item1c1e2adaf1
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice |
08-18-2011, 05:50 AM | #10 |
UCA63
Sorry about the mix up LH,I was referring to the OP's set up
T
08-18-2011, 11:30 AM | #11 |
oh.....i didnt think your post was for me i was just adding to the original poster that i had a long style and still had to space it .....after reading the thread again the "jfyi" i used did sound like i was responding to you...no malice meant here.
