Old 08-17-2011, 10:27 AM   #1
68gmsee
Active Member
68gmsee's Avatar
Cheap $10 overflow- how to and pics.
I've been asked how I made a my overflow by a few members so I'm posting some pics of what I used. Cost in parts was less than $10 at the local Lowes about 3 years ago. May be more these days. This overflow can be placed in any convenient place and painted to match if needed. Recently I've tinkered with the idea of a nylon or copper fitting on the top cap but for now it works well.
1. Two inch by 2 foot section of black pvc pipe , two end caps and a can of pvc glue at Lowes. Any 2" pvc pipe with end caps will do.
2. I cut the piece to 16" to fit between the radiator support and grill on mine (you can place in any convenient location)
3. Glued the bottom on and left the top unglued.
4. Drilled a 1/2" hole on the top cap to fit the hose (may be smaller depending on hose diameter)
5. I mounted mine using an old fire extinguisher clamp. Nylon or metal tie straps or U clamps can be used.
6. Drilled a 1/2" hole in radiator support to feed the hose through. It can be looped on top also if you don't want to drill a hole there. If you do drill make sure there's nothing obstructing it on the other side before drilling.
7. Cut the end of the hose at a slant and insert it until it just touches the bottom of the container. The top can be removed to check fluid since it's not glued.
8. Buy a cap that is rated for the engine you have and that allows fluid to be drawn back into the radiator as it cools.
[IMG][/IMG]
[IMG][/IMG]
68gmsee is offline   Reply With Quote
Old 08-17-2011, 10:50 AM   #2
big_al_71
big_al_71's Avatar
Re: Cheap $10 overflow- how to and pics.
Great idea...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-17-2011, 04:26 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Yeah, it's a cheap way to see if it would help my over heating problem and I was amazed at the difference it made on my truck. Has not overheated even in this 100+ heat over here.
I had tried hoses, flushing, water pump and finally a double row radiator. Still would run hot around town and always had to add water. Now it stays at 185° and full all the time.
Old 08-17-2011, 04:55 PM   #4
r&r419
Awesome idea!! Like you said if you paint it, most people will never even notice it. Great way to conceal it!! Will be doing this in the near future!!
r&r419 is offline   Reply With Quote
Old 08-17-2011, 07:01 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
cool idea! need a link to this added to the under $50 budget mods thread
Old 08-17-2011, 07:38 PM   #6
Shane
Shane's Avatar
how does it pull the coolant back into the radiator after it cools down?
Shane is offline   Reply With Quote
Old 08-17-2011, 11:24 PM   #7
CPNEJR
CPNEJR's Avatar
It will suck the coolant back by expansion and contraction. When the liquid is hot it expands into the resevoir and by it cooling down it will suck it back into the radiator. Thats why he had to cut the hose at an angle and put it in until it just touched the bottom.
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 08-18-2011, 01:33 AM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Cool Idea!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 08-18-2011, 10:48 AM   #9
eagleuh1
eagleuh1's Avatar
Cool idea. Seen people use the little aluminum water bottles for $5 at Walmart also, with the muffler clamp holding it to the fender or core support. I copied that idea for a washer fluid bottle. The PVC pipe you can make bigger and have more volume though.
eagleuh1 is offline   Reply With Quote
Old 08-18-2011, 11:34 AM   #10
DT1
DT1's Avatar
Had a hard time seeing it. It looked like an AC drier.
Very cool.
DT1 is offline   Reply With Quote
Old 11-17-2013, 02:09 AM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I like how it's placed inconspicuously.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 11-17-2013, 11:29 AM   #12
GMC Canuck
Nice and simple, I like it.
GMC Canuck is offline   Reply With Quote
