#176 |
Re: Post your best budget mods! ($50 or less)
Side View... thought I had it uploaded at the same time
Eric "Target" Sherwood Professional Bullfighter For Hire God Bless and Gods Speed! TheCowBoyProtectionUnit@yahoo.com http://www.facebook.com/pages/Eric-T...59496227444241 |
#177 |
very interesting bench ya got! keep everyone posted cause i am sure im not the only one , what are your plans? keep the same fabric?
#178 |
Plans for it are to Match the Color of the Truck... Blue Or...... Grey Leather Possibly Something that Cleans Up easy, and doesn't hold Dog hair.... My Dog Sheds Horridly... I've seen these trucks around off and on its the old school equivalent to today's Western Haulers and Such.....
#179 |
very cool stuf!
Subscribing!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#180 | |
Re: Budget throttle rod
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
#181 |
![]() Join Date: Feb 2008
Wonderful Thread. Mind would be a box of Mr. Clean scrub sponges. Not sure if thats the right name. I have cleaned a lot of chrome with these to get off brake dust, corrosion and whatever. With a little bit of chrome polish or cleaner they work beautiful. I swiped mine from the wife's kitchen so I don't know the price.
The more I learn, the more I find out I don't know. 69 Chevy SWB w/67 front end 4 wheel discs 468 BB 700R4 Bagged Coming around slowly |
#182 | |
Old member
![]() Quote:
It's going to get a 3 hr or so trip tomorrow so I will see how it does out on the interstate running 70-80 MPH! ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#183 | |
Redefining LowBudget
#184 |
I just saw the commercial to Mr Clean Erasers. Not scrub sponges like i said earlier. Wonderful product for the Truck or anything else your detailing.
#185 |
Old member
Well I have been replacing all the gauges in the 71 with SpeedHut and I did away with the speed-O cable to the transmission. So I needed something to cover the hook up on the side of the tail shaft.
Bought a $4.00 box at O-Rileys auto store of rubber cap plugs. The biggest one fit like a glove over the end. No dirt getting inside now! The threads will hold it on to! ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 08-30-2011 at 07:31 PM. |
#186 |
good stuff, to the top :-X
#187 |
I made a throttle linkage from a stick of 1/4" Aluminum rod. Threaded both ends, bent to the right angles, three locknuts for back stops and done. Whole thing cost about $2.69 - looks and works much more gooder than the old cable the PO had on it.
#188 |
Old School
I guess you could call this a repair/modification. I kept having problems years ago with the hollow rubber housing in the carrier bearing deteriorating and falling apart, resulting in the drive shaft flopping around. So the last time I replaced it, I pumped the hollow area full of silicone sealer and there has been no problems since. Caulking gun and tube of silicone sealer definitely come in under $50.
Also, vacuum port plugs slipped over your zerk fittings will keep them well protected, offering protection from rocks and rust.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
#189 | |
Old member
![]() Quote:
#190 |
Old School
This modification does not concern the bearing so much as it does the hollow rubber housing surrounding it. On my carrier bearing housing, the outer metal housing has 3)...1/2 inch square openings at 2:00 / 6:00 / and 10:00 o'clock. I pumped silicone sealer into these openings until the hollow space inside the rubber boot could hold no more. If the metal housing does not have any holes around the outside, you can drill a couple of 3/8" holes in it and fill from these holes. It may take a day or two for the sealant to harden properly. In the past, I have not had as many problems with the bearing itself as I have with the rubber boot.
#191 |
Old member
Yea me to. The bearings always seem fine it's the rubber boot that tears and then the bearing starts hitting the metal housing. I have a spare shaft I keep a new carrier on so when the other one messes up I just replace it. It's been awhile since the last replacement though this is a good idea. I may do this and see how it works. Thanks
I was thinking about the CCP bearing. ![]() ![]()
#192 | |
Old School
#193 |
Old member
#194 |
Not mine, but I stole it from LocDoc on another post.
1986-1996 Dodge Dakota doors seals - they are the push-on style and fit great. Just had to cut about 4" off one end and I had new seals that I didn't have to mess with gluing on. Only problem is that now I have to slam the doors closed. Grand total of $6 from the U-Pull-It. Thanks Leon!
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
#195 | |
#196 |
not a mod but truck related...I pulled our 67 out of garage today, ... power steering fluid leak spot on concrete.... for floor dry I used Dirt ... it works good.sweeps up good,price is good
eat,work,spend,sleep,repeat. |
#197 | |
Cool Truck
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
#198 | |
Yup - that's it. It took longer to remove my glued on ones than to put these on. As Leon recommended, you will need a phillips screwdriver and small prybar to get the trim off the Dakota to remove the seals, but otherwise, they are a quick press-on fit. There is a small (3-4") inner piece that goes inside the seal to keep the ends together, so be sure to keep it (will work fine without it, but makes it fit better).
#199 |
Not too old to learn
Great thread. Learning a lot.
I'm subscribing to this, cuz not to bright to think of these bright ideas. ![]()
1968 C10 a way to long restoration. |
#200 | |
Cool Truck
