08-21-2011, 12:35 PM | #1 |
It followed me home?
Trailer brake problem, please help!!!
I friggin hate trailer brakes!!! ok here is my issue. First off I dont have a ohm/voltmeter here so that isnt helping. However, I do have a +12v test light which shows power coming through the trucks trailer plug, power going to each brake, and can hear the brakes humming when I hit the brake or slide the manual brake on the controller. When I use the slide on the controller the +12v light does get brighter but brakes wont engage.
I have adjusted the brakes several times and I'm pretty sure thats not the issue. Just to be positive I tightened them all the way down and the still wont engage with the truck. What am I missing?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
08-21-2011, 01:16 PM | #2 |
Kid's Mechanic
Re: Trailer brake problem, please help!!!
Do you have a good ground thru the trailer plug ?
08-21-2011, 01:43 PM | #3 |
Yep, i even ran a separate ground from the truck to the trailer
08-21-2011, 01:48 PM | #4 |
How is the ground point for the brakes themselves? Check them for corrosion.
Alex. |
08-21-2011, 02:09 PM | #5 | |
The drum does have some grooving where the magnet grabs the drum? Wonder if that would cause issues?
08-21-2011, 02:11 PM | #6 |
Kid's Mechanic
I wonder how much wear may be on the magnets inside the drum , The magnets do wear out
08-21-2011, 02:44 PM | #7 |
Rottenwood Garage Member
This is normally the case along with glazed drums. With age the magnets get weak. I just re-did one of my many trailers and took the cheap way out and did not replace or cut the drums after replacing all the backing plates. They grab but wont stop. I am about to break it all down again and cut the drums.
2004 Chevrolet Suburban C1500 2001 Chevrolet 2500HD Crew 6.0 1999 Harley Davidson Electra Glide 1972 Chevrolet C-20 Custom Camper "Dump Truck" 1972 Chevrolet C-20 Suburban "Big Green" 1969 Chevrolet C-50 Wedge Hauler "Leonidis" 1966 C-10 2x4 short fleet 327 4 speed "Race Truck" 1952 Plymouth Cranbrook "Rican" (my grandfathers) 1931 Ford Model A Coupe "Black Beauty" 1930 Ford Model A truck "Club Cab" 4x4 Rottenwood Garage and Speed Shop.....where everything must be racy! It's not just a hobby..It's a LIFESTYLE!!! Thanks for nothing Barrett-Jackson You cant fix stupid or teach accountability! Time wasters, looky Lous and tire kickers are everywhere! |
08-21-2011, 07:40 PM | #8 | |
