08-21-2011, 03:27 PM | #1 |
Help putting tension on the Vbelt
Hi I am trying to put my vbelt back on and I have few questions. How much play should be in the belt? Do I just tug on the alternator until it's tight and then torque it down?
86 C20 2wd with 454 and Turbo 400 |
08-21-2011, 03:30 PM | #2 |
Re: Help putting tension on the Vbelt
Yeah, make sure it has at least a half inch of deflection in either direction. Don't make it guitar string tight. Tighten it down till you can push on it with a finger and have it move about one half inch. Not too loose, not too tight. Then lock it down.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
08-21-2011, 04:24 PM | #3 |
Ty. Just curious how to remove the fan so I can actually remove the entire belt?
08-21-2011, 04:26 PM | #4 |
Robert Olson Transport
i generally tighten them to about 1/4 inch past when the belt slack ends when you appy pressure to the belt..
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
08-21-2011, 04:38 PM | #5 |
If you wanna take the fan off you should have 3 or 4 nuts between the pump pulley and fan to remove it. They should be a 1/2" nut.
08-21-2011, 06:15 PM | #6 |
You don't have to remove the fan to get the belt off. Slip the belt over one of the fan blades then turn the fan, and then slip the belt over another blade, and turn the fan again. Keep it up til the belt is off.
08-21-2011, 08:41 PM | #7 |
Yup no need to remove the fan. Or if you know the new belt will be the correct fit I just cut the old ones off saves a lil bit of time.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
08-21-2011, 08:51 PM | #8 |
I'm not sure why you need to remove the fan in order to remove the belt - you can thread the belt around the blades of the fan and slip it off - I must be missing something here.
There is a rule of thumb on belt deflection based on the length of the belt, but I just tighten until the belts don't squeal because I have an air pump, which means that the belt has to be very tight in order to not squeal. The fan is attached to the water pump pulley with 4 short threaded studs and nuts (usually with lock washers). If you do remove the fan you might want to replace those studs and nuts/washers since they tend to seize up and not want to turn after years of being in place. |
