Old 08-08-2003, 11:28 PM   #1
backinblack
Turn Signal Switch
A couple weeks ago, I changed the turn signal cam, and now discovered that the reason my horn doesn't work is that somehow I am missing some parts........It seems there is some kind of copper? contact connected to a spring that resides in the turn signal switch, and then makes contact with something that turns around with the wheel........I seem to be missing the part that turns with the wheel, and someone somehow has taken out the copper plug connected to the spring inside the turn signal SWITCH.....My question, How hard is it to remove the turn signal switch, ( I have removed the three phillips screws, and it doesn't seem to want to come out), are the wires connected to it removable, and where can I buy (if possible) these parts? Thanks for all the help.............
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Hmmm. Too many pontiacs, not enough chevy trucks yet.
backinblack is offline   Reply With Quote
Old 08-08-2003, 11:37 PM   #2
krue
Designated A-hole!
krue's Avatar
If I remember correctly the wires come loose and the assembly will come out with a little help. But I could be wrong!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 08-08-2003, 11:38 PM   #3
jef5150
Inline 69
jef5150's Avatar
Lightbulb heres a diagrahm
look at the parts list ,,,maybe you can see what your missing in parts,,,,jeff
jef5150 is offline   Reply With Quote
Old 08-08-2003, 11:43 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Heres my old one. You have to remove the clip for the flashers and wiggle it out past the red button.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 08-09-2003, 12:18 AM   #5
backinblack
So, the wires DO come loose? Excellent replies so far.....Thanks!
69 chevy SWB
70 GTO
65 GTO hardtop
65 GTO ragtop
77 Trans Am
Old 08-09-2003, 09:06 AM   #6
70c10
67-72 Addict!
70c10's Avatar
I cut the wires to remove mine. The plug will not fit thru the opening in the cup. My new one has a different plug and I grinded the end off that was not needed. I got mine at the Chevy dealer and it works up to 1987 models. I now have a modern looking flasher button but I didn't care about the look.
Jim
Old 08-09-2003, 11:35 AM   #7
jef5150
Inline 69
jef5150's Avatar
cover
remove the cover w/tabs thats under the column[be gentle w/tabs you dont want to snap them off}
Old 08-09-2003, 12:14 PM   #8
jef5150
Inline 69
jef5150's Avatar
getting wires thru column,,,,,,
your "probably" gonna have to dis- assemble connector of new harness,(under dash end),to get wire thru column,then re-assemble it after wires are in,,if your replacing "ENTIRE HARNESS",cut half moon connector of "OLD" connector,leaving some of the wire attached,,but save the connector,youll need it as reference when you install the new harness,,
Old 08-09-2003, 12:19 PM   #9
jef5150
Inline 69
jef5150's Avatar
Thumbs up 1 more pic......
Old 08-09-2003, 04:23 PM   #10
70c10
67-72 Addict!
70c10's Avatar
Those are great close up shots!
Jim
Old 08-09-2003, 05:13 PM   #11
jef5150
Inline 69
jef5150's Avatar
thanks----the camera is pretty old, butt it still works,i only have b&w film....lol
Old 08-09-2003, 11:22 PM   #12
palallin
once you've gotten that far into the column, pulling the collar off isn't too hard, and then you don't have to cut any wires or disassemble the connector.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
