Anyone installed VintageAir in their non-factory AC cab?
I havent seen this done so I am curious how this works. Does the Vintage Air kit come with the vents to install? Do you have to cut the wholes in your dash of do they have those vents that just mount under your dash?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
Re: Anyone installed VintageAir in their non-factory AC cab?
Brian, Im going to watch this thread as I want to add air to mine next year maybe but I dont care if the vents are added or not. I would be perfectly happy with under dash vents if they are made that way like the old dealer added A/C from way back.
You can either cut dash and install their in-dash vents or most people use the OEM vents,which obviously need to be cut in,too. I'm not sure if an under dash vent set-up is offered.
I've always cut the dash for OEM vents. The underdash looks to added on for me. Let me know if you have any other questions. I've done a bunch of vintage air installs.
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 |
Eric... I need to ride up and see your place. Id love to see some of the work you guys have done. Are yall up there on the weekends?
I used the Vintage -air Gen-2 universal kit. It was quite a chore to put in. I used under dash outlets. I probably should have used the custm kit but my firewall under the hood is clear. It works real good. I just bought the inside kit & used a factory compresser & a salvage yard cond.
Could you guys post some pictures of these systems installed on your trucks? I'm either gonna get AC soon or a divorce!
1972 C-10 Deluxe 350 V8 - 350TH ------------------------------ We're not the jet set We're the old Chevrolet set |
![]() Join Date: Nov 2007
This fellow did a nice write up with lots of pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=249479
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
Are there any more pics of a Vintage Air install?
How does someone get a really clean install like this one? ![]()
Here are some pictures of the vintage air install in my crew cab with a smooth firewall.
Looks pretty clean... Are all the hoses run thru the fender?
Yep, but when I installed the vintage air in the 67 they were ran a little bit different. The orange truck was done before the crew cab, I like the hoses tucked behind the inner fenders.
![]() Join Date: May 2007
do you guys have any issues with the unit sweating under the dash?
There is a hose that vents the water out the cab.
#15 |
Most saturdays and every once in a while a sunday. Come on up!
Eric Evans Queen City Shop Truck http://67-72chevytrucks.com/vboard/s...34#post6139834 66 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=543110 Last edited by eldogg; 08-23-2011 at 08:48 AM. |
#16 |
Universal compac kit and custom lines. Piece of cake....
#17 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
ttt
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
