Old 08-21-2011, 11:56 PM   #1
Dave K
Dave K's Avatar
Can you mod the stock ebrake to work when you slam a 1955-59?
I notched the frame and cross member on my 1959 and now the drive line rubs on the ebrake thingy. Has anyone documented a mod to retain the the stock ebrake on a lowered truck?
Thanks for any ideas
Dave
Dave K is offline   Reply With Quote
Old 08-22-2011, 01:04 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Can you mod the stock ebrake to work when you slam a 1955-59?
You could remake the cross bar and put a higher bend in it to raise it up about an inch. That should get it out of the way. The other option is to use a lokar setup and get it out of that area entirely.
Old 08-22-2011, 02:58 PM   #3
OrrieG
OrrieG's Avatar
Or you could bend the crossbar vertically then back horizontal up to get some clearance. Or make a new mount for the cross bar that goes on top of the frame.
Old 08-22-2011, 03:04 PM   #4
OrrieG
OrrieG's Avatar
Or you could bend the crossbar vertically then back horizontal up to get some clearance. Or move the bar circled in red below up to the top of the crossmember. On my truck it looks like there is enough room. Cable from the front would move to the top too.
Old 08-22-2011, 08:34 PM   #5
Daze57
Daze57's Avatar
all good ideas
Daze57 is offline   Reply With Quote
Old 08-22-2011, 09:13 PM   #6
Dave K
Dave K's Avatar
Cool thanks for the help. I will post progress when I have time to modify it, could be a few months before I get to it.
Dave
Old 09-14-2011, 01:33 AM   #7
Dave K
Dave K's Avatar
I need a quick fix so I can hall stuff to billetproof this weekend for the swap meet so this is what I came up with. You can see the line on the paper that is the original shape of the cross bar and the new shape gives me a good amount of additional clearance. I think I am just going to take a nice size notch out of the cross member as it does not need to be that strong (I hope). Do you think it will work?
Old 09-14-2011, 12:32 PM   #8
OrrieG
OrrieG's Avatar
On lowered trucks on this site I have seen that member notched in an arch for drive line clearance with a piece of 1/4 - 3/16" stock welded in the bottom to the remaining piece for reinforcement. It does not hold any vertical weight just cross braces the frame laterally.
