08-21-2011, 08:05 PM | #1 |
Wheel Spacer Question For The Circuit Rider?
I have discovered the aluminum shavings came from where the passenger side control arm is rubbing the inner lip of my TT Original wheel. I have two options: #1) use a spacer (I will need about 1/2") or #2) buy two new front wheel with about 1/2 inch offset.
Whats the best long term approach. The truck has 2 1/2" drop spindles with factory springs.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
08-21-2011, 08:43 PM | #2 |
Re: Wheel Spacer Question For The Circuit Rider?
I have never used spacers, but I would not use them personally unless I didnt plan on driving the truck. I would buy new wheels but Im sure others will chime in and say spacers are perfectly ok... Funny thing is I helped lower a friends 99 GMC this weekend and the same thing happened, the lower a arms rubbed the wheel. (4 inch drop) He wanted spacers but we'll see what happens. I hope it works out for you, I know the Circuit Rider is NICE no matter what
72 C20 Longbed 05 1500 Z71 |
08-21-2011, 09:45 PM | #3 |
I run spacers on the back of my 72 blazer. I routinely put around 5000 kms a year on the truck. Not all of those kms are friendly either. I have never had an issue with them. My uncle (member reefer55) also runs a set with no issues. Just my 2 cents.
Jason Posted via Mobile Device
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
08-21-2011, 09:53 PM | #4 |
Active Member
I have never cared for spacers - they are hard on bearings and tend to move the point of load further out
Addtionaly you might need longer wheel studs to make sure that you have enough engagement of lug nut threads What are the demsions of your wheel?
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
08-21-2011, 09:56 PM | #5 |
67-72 parts collector,…
What's the backspace of your current wheels?
08-21-2011, 10:01 PM | #6 | |
15x7 I thought I would be ok with these but the aluminum shavings we found at the hotel/meet was due to rubiing issues. I think 1/2" more clearance will be plenty. The driver side seems to be ok. I think I am leaning to new wheels.
08-21-2011, 10:07 PM | #7 |
Have you trimmed the lower a-arms?
I bet it only rubs when the wheels are turned. 15x8 ralleys have 4" of backpsacing. Surely 3.75" BS can be made to work. (especially with stock springs)
08-21-2011, 10:08 PM | #8 | |
There are different type of spacers. There are rings that just slip over the lugs and are pinched between the rim and hub. Longer studs may be required. The other kind bolts to the old lugs and provides new lugs to mount the rim on. For 1/2", I would use the 1/4" ring kind, 2 on each side. And keep check on my bearings.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-21-2011, 10:09 PM | #9 |
The AR TTO wheels only come in 1 backspacing. (3.75")
You can't custom order them. http://www.newstalgiawheel.com/wheel...ubcat3=1011104
08-21-2011, 10:13 PM | #10 |
You are correct...only on turns. I had the same issue with the 15x8 Ralleys.
08-21-2011, 10:13 PM | #11 |
Trim the a-arm and be done.
08-21-2011, 10:15 PM | #12 |
I'll look at that option first... I need to measure exacttly how much interferance that I have. I appreciate the input. I am now in the fine tuning stage.
08-21-2011, 11:34 PM | #13 |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
08-22-2011, 08:16 AM | #14 |
I have some concerns about this. My truck has 2.5" drop spindles and 1" drop springs. The old 15x8 Hopsters I had on before had 3.75" bs. They NEVER interfered with anything.
This leads me to believe that you may have another issue. I also find it strange that it rubs on one side, but not the other. What brand are your spindles?
08-22-2011, 08:59 AM | #15 | |
I would look at both lower a-arms.
08-22-2011, 10:18 AM | #16 | |
Its interesting that Ralleys have the similiar issues. As I have read old threads it seems that some people have rubbng issues when with drop spindles when they turn and some people don't.
08-22-2011, 10:39 AM | #17 |
I had a similar issue with some of my old projects and I found that the best solution is to look at the wheel Lock to Lock and see when it is rubbing. More than likely it is the rear of your control arm and if it is then you can just Adjust the steering stop on the lower control arm by adding (Welding) a small amount of material to the contact face where it touches off on the back side of the spindle casting. (if it is the front you add material to the opposite side control arm) This eliminates a need for cutting the control arm and has a minimal change in your turning radius.
Hope this helps. |
08-22-2011, 07:46 PM | #18 |
Here is where to add thickness to reduce the wheel travel.
