Old 08-24-2011, 06:32 PM   #1
Glennerd
Glennerd's Avatar
Heater core/fan shroud repair
Is there a way to repair the housing? I have a small crack that could become a problem later. It is located on the underside, so cosmetics are not such an issue. Thanks for any help.
Glennerd is offline   Reply With Quote
Old 08-24-2011, 08:48 PM   #2
Glennerd
Glennerd's Avatar
Re: Heater core/fan shroud repair
Can someone please tell me what it is made of? Appears to be similar to a fiberglass compound.
Old 08-24-2011, 11:45 PM   #3
Glennerd
Glennerd's Avatar
Red face Re: Heater core/fan shroud repair
Old 08-25-2011, 03:21 AM   #4
plummen
Originally Posted by Glennerd View Post
can you post a picture of the damage?
plummen is offline   Reply With Quote
Old 08-25-2011, 01:23 PM   #5
Glennerd
Glennerd's Avatar
Will post pics of the repair tonight. It's just old school glass apparently. I used JB quick on it and when sanded, the repair is nearly invisible. The 2 part jb quick uses a light grey hardener and a black resin. The others won't sand out as close of a match in color.
Old 08-25-2011, 01:26 PM   #6
plummen
did you drill a hole in the end of the crack to stop it from coming back?
Old 08-25-2011, 01:34 PM   #7
Glennerd
Glennerd's Avatar
It was broken (chipped) around the lower core outlet. I had a donor, so I made a template a bit larger than the damaged area, cut it out and did the same with the donor. A little filing to get the fit and I must say, pretty much invisible. I wasn't all that gentle with the file, so I'm sure it will hold.
Old 08-25-2011, 06:33 PM   #8
Glennerd
Glennerd's Avatar
Some repair pics.
Old 08-25-2011, 06:36 PM   #9
Glennerd
Glennerd's Avatar
This is my kitchen table. I rent my women. Cheaper and less *****ing.
Old 08-25-2011, 09:35 PM   #10
plummen
that turned out nice! i get to use the table at night after the wife goes to sleep!
Old 08-25-2011, 09:52 PM   #11
Glennerd
Glennerd's Avatar
Lol!
Old 10-05-2011, 07:35 PM   #12
Glennerd
Glennerd's Avatar
All done.
Old 10-05-2011, 08:54 PM   #13
FLcustom10
Very nice!! I'm impressed.
FLcustom10 is offline   Reply With Quote
