08-25-2011, 02:00 PM | #1 |
Grand PooBaa Member
Truck Not Centered
Im the second owner of this truck, my late great uncle was the first. It was hit at least two times when he owned it. I just notice this a few weeks ago. My front wheels stick out more on one side the other and there not centered.
The back are the same, yet one is close to the bedside and the other is centered. Does this mean my frame is bent just enough to cause this? I see no frame damage, but before I spend anymore money on this truck I need to know if its worth it. |
08-25-2011, 02:04 PM | #2 |
Grand PooBaa Member
Re: Truck Not Centered
The rear Wheels
08-25-2011, 03:40 PM | #3 |
I would have to say yes it last is tweaked. If you follow behind it it would probably look like a dog running.
Mick 1972 C20 Deluxe MADE IN the U.S.A. |
08-25-2011, 03:50 PM | #4 |
I wouldn't jump to the conclusion that your frame is bent. Perhaps the cab was put on not quite centered on the body mounts (or pushed over in the accidents) and then the bad and front were put on to match (offset as well). Try taking some measurements from body to frame. If the measurements are off, then it probably just needs to be shifted over. If they are the same, then I would take some diagonal measurements of the frame to see if it is square.
67 5.3L Build |
08-25-2011, 04:47 PM | #5 |
Is the alignment fresh? Adjustments there can make a difference as well.
08-25-2011, 04:56 PM | #6 |
Grand PooBaa Member
08-25-2011, 05:02 PM | #7 | |
Grand PooBaa Member
SCOTI Im due for an alignment and I can see adjusting the caster, toe, etc etc. But you cant adjust upper and lower control arm out or in, so I guess im lost on how an alignment would help the whole truck. |
08-25-2011, 05:43 PM | #8 | |
The body placement on the chassis is a common issue on older vehicles. Small to moderate collisions over the years can easily shift the body toward one side or if the impact was to a rear corner it could 'diamond' things (one corner forward, the other back). If the truck was known to have been in minor collisions, it's a good idea to have the chassis validated as being square so you're not wasting time/money chasing a ghost. Make sure the alignment is good (needs to be done anyway, right?). If things are still 'off', start measuring reference points on the body to the chassis & compare side to side (take as many diagonal measurements as possible).
08-26-2011, 02:35 PM | #9 | |
Grand PooBaa Member
The driver side was know to be hit especially when parked. In fact the driver side of the bed had Bondo from the tail light to the front of the bed behind the cab. And from the top crease all the way down. So the whole bedside was bondo. Driver side front fender and driver door, also bondo, just not as much. I've pulled 1 to 2 inch chunks of bondo off. So your theroy of the body shift could be correct. I will get everything align and measured. Thanks again. |
08-26-2011, 04:43 PM | #10 | |
I had one done in 09. The inspection plus the pull/straightening was $300.
