08-09-2003, 11:33 PM | #1 |
Removing Fuel Sending Unit from fuel tank
So I've removed my gas tank on a '76 elky and to find out the rust situation inside you've got to remove the sending unit, which is basically one of those circle things, sitting on top of the tank with hoses coming out, and seemingly have no way to be opened. everybody I talk to says they've never heard of a tool (plumber's tool?) to open them. It seems the tool of choice is a brass drift and a mallet/hammer. I know it may work, but it just doesn't seem right. Plus I'm a bit worried b/c there is a whole lot of rust and I don't want to destroy it while trying to open it. anybody have a better idea?
08-09-2003, 11:43 PM | #2 |
You get what you pay for
Hammer and screwdriver works for me.
Mike 1985 Chevy C-10 |
08-10-2003, 12:28 AM | #3 |
5 day ban, learn to behave.
soak it with some WD40 or similar real good beforehand and you shouldnt have any problems.
08-10-2003, 10:41 AM | #4 |
Robert Olson Transport
ive always soaked it in liquid wrench for a few hours prior to the hammer and screwdriver method.... and if ya have a rubber mallet, you can try a copuple of raps in the general area to loosen it before ya try moving the retaining ring
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
08-10-2003, 04:51 PM | #5 |
it worked! i soaked it pretty good with some WD-40 and then just used a drift and hammer. The thing popped open no problem, of course the gas tank looked tip-top so there really wasn't any reason to do it in the first place, but I had to make certain.
thanks for the help. |
08-10-2003, 06:08 PM | #6 | |
I'm back with 2nd truck!
Re: Removing Fuel Sending Unit from fuel tank
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
12-16-2007, 03:58 PM | #7 |
Here's the tool -Lord only knows where to get one. Hopefully I can use the above mentioned method tomorrow.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
12-16-2007, 04:39 PM | #8 |
after four years he broke down and bought a new tank
12-16-2007, 04:51 PM | #9 |
I know, I know, it's an old thread, but if I figure I can add something that makes it a little more complete, then it's a little more usable for someone looking up a thread for this procedure.
12-16-2007, 09:31 PM | #10 |
I had one I did a while back that was severely rusty. I was concerned that it would break instead of twisting out, so I wd40ed it several times over several days, then I took a screwdriver and pried the tabs up slightly, then it twisted out fine. before I reinstalled I cleaned as good as possible and bent the tabs back then twisted it back. I would only recommend this if the tank\ lock ring is so rusty that you don't believe it will come out by just tapping! If you plan on keeping the elcamino I would recommend a new tank if it is that bad! One other thing. the tanks on all trucks/cars under (in that vintage) 40 series is galvanized steel. it isn't likely for the inside to be that rusty without holes in the tank. If you have that bad of a rust issue, I would wonder about where you are getting gas.
12-19-2007, 07:05 PM | #11 |
89 crew, note the date on that el camino post. I brought this up to add a little to this thread to make it a little more valuable to someone's who's doing a lookup on installing a sending unit. Mine came out fine, I put the new one in, and...realized that the truck had a 2 barrel carb originally, and I had put in a motor with a 4 barrel. Meaning the fuel line was all 5/16, and I had installed a sending unit with a 3/8" connection. So I got to replace all the fuel line from the tank to the fuel pump. I have to say, it starts better now, though. I probably should have done that when I put the motor in. Just something to remember for next time.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 Last edited by dan42; 12-19-2007 at 07:24 PM. |
