Old 08-26-2011, 10:14 PM   #1
Andy4639
Old member
Andy4639's Avatar
Cool GPS, SpeedHut update
Well I did some tinkering today to see what they will look like. These things are nice and very easy to do so far anyway.
I have to pull it all back apart to paint the ring around the Gas and speed-O to match the truck. Except for the space around the gas guage I love it. I have to find the dash wire for the lights and a 12v ignition wire and ground thats it. I'm going to use the dash for turn signals I guess, I may buy 2 LED's for them and install them in the normal place.
Here is a daytime picture.
Backside:
All the wires will be inside the cluster so far.
Night time:
Night time with high beam, had to move it over the fuel guage because of room around the speed-O. Sorry picture taking is not my strong suit!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-26-2011, 10:47 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: GPS, SpeedHut update
That looks good Andy. I think the space will be fine once you get it painted.
LockDoc
Leon
Old 08-26-2011, 11:35 PM   #3
Andy4639
Old member
Andy4639's Avatar
Cool Re: GPS, SpeedHut update
Yea me to!
I ran the GPS anntena through he drivers side weep hole and put it in the middle of the dash. I stuck the cable up under the windsheild gasket so it want be so noticable. I'll get pictures tomorrow for you. I may run it to the back window and run it out the cargo light some how if I can figure how to get it through to the outside.
I looked over all the directions and it's pretty much a plug and play except for the wiring to the factory wires. I guess I need to check on which wires are which in the factory harness to tie to.
The only thing right now is the brightness of that LED high beam light. I may have to tone it down some!!!!
Old 08-26-2011, 11:56 PM   #4
LockDoc
LockDoc's Avatar
Originally Posted by Andy4639 View Post
Yea me to!
That thing looks like a flashlight...
LockDoc
Leon
Old 08-27-2011, 09:09 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: GPS, SpeedHut update
Yea I know!
I wonder if I hooked it into the converter with the guages would that tone it done a little? I mave have to find a smallr one for it. They had smaller amber,green but no blue.
Old 08-27-2011, 09:51 AM   #6
LockDoc
LockDoc's Avatar
Yea I know!
Maybe you could put a resistor in the wire or something. You may have to post over in the electrical forum or PM VetteVet and ask.
LockDoc
Leon
Old 08-27-2011, 10:45 AM   #7
71swb4x4
71swb4x4's Avatar
I thought the exact same thing before I read LockDoc's post. A resistor may be the ticket.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 08-27-2011, 11:18 AM   #8
Andy4639
Old member
Andy4639's Avatar
Question Re: GPS, SpeedHut update
I check on it and see. Thanks!
I got the dash tore apart and primered. I hope to gt the wiring done on the truck today. I have to go get some fittings for the oil sender.
Old 08-27-2011, 04:13 PM   #9
Andy4639
Old member
Andy4639's Avatar
The old dash is out.
New oil sender is mounted and ready to wire.
Dash insert is primed & painted.
Old 08-27-2011, 04:30 PM   #10
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Looking good!! Man with that big of a gas gauge, I bet you can just watch it move like a temp gauge when you have a heavy foot. Atleast you would be able to in mine. Do they make a tach the same size as the spedo?
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 08-27-2011, 05:51 PM   #11
Andy4639
Old member
Andy4639's Avatar
Thanks,
Yes they have the same size tach's. The fuel gauge was a special order though.
Now a ? for you all.
Factory cluster plug has 2 connections that state.
Fuel gauge feed wire
Fuel gauge wire.
Which one of these do I need to hook up to?
I had them program it to chevy gas gauge before they sent it out so all I need is one wire. I hope!
Old 08-27-2011, 11:27 PM   #12
Andy4639
Old member
Andy4639's Avatar
Got it back together. Going to wait and install it in the morning! It shouldn't take to long, I have all the wires ran but the fuel.
Old 08-27-2011, 11:45 PM   #13
LockDoc
LockDoc's Avatar
That thing looks great. It will sure change the looks of the interior, that's for sure....
LockDoc
Leon
Old 08-28-2011, 09:45 AM   #14
Andy4639
Old member
Andy4639's Avatar
Thanks Doc, I'm drinking my last cup of coffee and headed out to start on it again. Can't wait to see it all back together again.
As you see in the picture I'm using some of the stock lights and some non so stock lights. I hope this will work out OK.
I may have to pull the stock bulbs if it lights up to much.
Old 08-28-2011, 10:17 AM   #15
BIG ORANGE
BIG ORANGE's Avatar
Andy your always up to something different on these trucks! But I got to hand it to ya, what you do always turns out great............
Takecare and hope to run into ya again some day.
Donnie
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 08-28-2011, 12:16 PM   #16
Andy4639
Old member
Andy4639's Avatar
Donnie
Thanks Donnie,
It's been awhile. May get down there now though. My sister is moving there next month. They are coming back from Tenn. Her husband took another job.
Old 08-28-2011, 05:59 PM   #17
Andy4639
Old member
Andy4639's Avatar
The dash is back in but the gas gauge is kicking my ass! I have hooked it every way I know how to except for running new wires all the way back to the tank.
Guys I need some help with this please some body. I have tried the tan and red wire each both blow the fuse in the fuse block if I hook both the wires up to the gauge.
Notice I went to a red light for the high beam, the blue one wouldn't work after one click.
Old 08-28-2011, 09:02 PM   #18
ERASER5
ERASER5's Avatar
I noticed that the Speed Hut GPS speedo can be order with the high beam and turn indicators internal. This could solve some issues for full custom dashes. I still haven't figure out a custom "Brake" light though. I'm always watching for good ideas.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 08-28-2011, 10:10 PM   #19
Andy4639
Old member
Andy4639's Avatar
It's a little late for me though. I should have study it better before I ordered it.
Old 08-28-2011, 10:52 PM   #20
LockDoc
LockDoc's Avatar
How does the SpeedHut wiring diagram say to hook it up? I think the Tan wire would be for the ground through the sending unit. Did the original fuel gauge work OK? SpeedHut has a Chat on their web site or you could e-mail them....
LockDoc
Leon
Old 08-29-2011, 08:32 AM   #21
Andy4639
Old member
Andy4639's Avatar
Doc,
old gauge worked fine never had any problems.
SpeedHut directions:
New gauge says white wire to fuel sender out put
Black wire fuel sender ground
NOTE:
The ground is optional if your sender does not have one don't use it.
Factory wiring on back of dash has 2 wires listed on it for the gas gauge.
1 wire is Tan it say's Fuel gauge.
1 wire is Pink/RED says fuel gauge feed.
Yea I was going to call them this morning and see what they say.
Old 08-29-2011, 10:19 AM   #22
Putter
More Cowbell....
Putter's Avatar
PM sent about your fuel gauge connection.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 08-29-2011, 12:02 PM   #23
Andy4639
Old member
Andy4639's Avatar
Unhappy Re: GPS, SpeedHut update
Thanks, I did as your PM suggested with no luck!
I'm going to call them as soon as they open. It will be noon here when they open.
Old 08-29-2011, 02:39 PM   #24
Andy4639
Old member
Andy4639's Avatar
OK,
between Putter and the SpeedHut tech I got it all working!!!
Had 2 problems with it.
1st was 2 bad connectors in the wiring harness they sent.
2nd was the gauge itself had never been programed for the truck like they said they do.
I got everything fixed and it's ready to go back in the truck.
Got the Fuel/ Air gauge working to, it was one of the bad connections.
Old 08-29-2011, 05:40 PM   #25
Andy4639
Old member
Andy4639's Avatar
Don't have the warm fuzzy feeling yet on the gas tank gauge. It's showing full but it should only be about 1/2 are a little more than 1/2.
I have the white wire hooked to the tan and the black wire hooked to ground. The speed hut tech said that should be how it works but I'm not 100% sure that's right yet!
