Old 08-29-2011, 05:20 PM   #1
48richard
48richard's Avatar
Is this an oil pressure port?
Is this plug (center of the picture, with a square head) a port that can be used for an oil pressure sender? It's a 350 small block; the plug is in the top of the block, just behind the water pump.
Thanks,
Richard
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 08-29-2011, 05:25 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Is this an oil pressure port?
not for sure, I'd just use the one back by the dist to be safe.
brad_man_72 is offline   Reply With Quote
Old 08-29-2011, 05:28 PM   #3
Mt Man Chad
Mt Man Chad's Avatar
Can be used for one....
It's the cross drilling between the main bearing's oil galley and passenger side lifter's oil supply galley.
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps.
68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread
Mt Man Chad is offline   Reply With Quote
Old 08-29-2011, 06:51 PM   #4
48richard
48richard's Avatar
Thanks. The one by the distributor is already in use for the oil pressure gauge, and I want to use the one above the oil filter for my electric choke wiring if I can get the plug out, but it's in a pretty confined space with the engine in the truck and headers installed. We'll see how it goes.
Old 08-30-2011, 06:25 PM   #5
C20-67_N_MO
Champagne Taste on Beer Budget
C20-67_N_MO's Avatar
Yes it is.
That is a sure way to ID the block is a 4-bolt main block as well.
Coming Soon: Project 1970 Country Truck
C20-67_N_MO is offline   Reply With Quote
Old 08-30-2011, 07:24 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: Is this an oil pressure port?
Mine has the backup oil pressure switch in it for the fuel pump relay. If the fuel pump relay fails this will keep voltage supplied to the pump as long as I have @ least 5PSI of oil.
I shold have wiped it off before I took the picture!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-30-2011, 10:20 PM   #7
Dark Knight
Dark Knight's Avatar
I'll have to disagree with this one. I have a plug there and mine is only a 2-bolt main block. I have an allen headed plug instead of a square headed plug, but I don't think that should matter.
-1967 Chevrolet Fleetside LWB- 350 V8 w/thumpr cam, NV3500, 3.08 gears, A/C, PS
-1983 Chevy Silverado C1500- 383 stroker, TH400
-1989 Chevy Silverado K1500 SWB- 5.3L swap, 700R4, 3.42 gears
-And a '66 Ford Mustang- 200 I6, C4 trans, rust bucket
"The only thing we have to fear is fear itself." -FDR (and maybe rust too)
You've gotta be able to stop and steer before you can go fast!
Dark Knight is offline   Reply With Quote
Old 08-30-2011, 10:27 PM   #8
Mt Man Chad
I would agree.
Thought it was a true sign of a 4 bolt from previous post.
The 1967 C10 I parted with a 283 has one but not a 4 bolt block, wish it was.
Old 08-30-2011, 10:35 PM   #9
48richard
48richard's Avatar
Thanks, guys. As usual I learn something from this forum every day. I have no idea whats underneath the orange paint on my engine, except that it's not original to the truck (no serial number), and it runs a whole lot better that I would expect a stock 350 to run.
Old 08-30-2011, 11:36 PM   #10
indianbullet
Location: North Cal and no Sac or Bay area is not NORTH
Back in the early 80's when I worked in a machine shop I won and seen many a case of beer lost by those that thought this # or that #, or this indicator could indicate a 4 bolt sb chevy. The only indicator was pulling the pan..
On a big block it was the huge pipe plug above the filter that indicated a 4 bolt but as I understand it later blocks can have the small plug and be 4bm's now days.
indianbullet is offline   Reply With Quote
