08-30-2011, 09:30 PM | #1 |
i need help quick im about to order and noticed something wierd about these spindles.
http://www.stylintrucks.com/parts/lo...qt-s/6212.aspx
they say 2" drop spindles but drop amount is listed as 2.5" can someone please clarify
08-30-2011, 09:39 PM | #2 |
Re: i need help quick im about to order and noticed something wierd about these spind
I don't see the 2-1/2" deal you're talking about. If the spindle is relocated 2" from stock then the drop will be 2".
08-30-2011, 09:41 PM | #3 |
Specifications:
* Anticipated Ship Out Time: 2-3 business days * Drop Amount: 2.5 in. * Product Fit: Direct fit * Warranty: Lifetime McGaughys limited warranty * Fit Note: o RWD, 1/2 Ton, With 2.5 in. Front Drop this is right underneath the written description, however mcgaughys doesnt offer a 2 inch spindle from their website so im just going to order and deal with it if its .5" short thanks for the quick response!
08-30-2011, 09:43 PM | #4 | |
08-30-2011, 09:54 PM | #5 |
the same 2.5 thats on mcgaughys site. 33154 1 inch rotors
08-30-2011, 10:05 PM | #6 |
That's a generic advertisement listing that's not specific.
Some trucks get 2" spindles (s10's or newer trucks). Some get 2.5 spindles (most 63-87's), & there are the Bell Techs @ 3" (73-87's). They just list them & the drop is dependant on the p/n.
08-30-2011, 10:06 PM | #7 |
yeah i figured, i ordered from the p/n from the site so all should be good, i also ordered 2 inch shackles.. the most money ive spent on a toy in a long time it hurts a lil
08-30-2011, 10:07 PM | #8 |
scoti, you mentioned a sway bar modification or change in another post, could you elaborate on what i should do to keep my sways further from the ground?
08-30-2011, 10:14 PM | #9 |
08-30-2011, 10:20 PM | #10 |
after paint and ill have a truck worth 1/3 of my investment
ugh i have 7k+ in it now...
08-30-2011, 10:21 PM | #11 | |
To do the install, I remove the sway-bar completely. Knock off the factory sway-bar extension brackets (grind/drill the rivets out). Bolt the sway-bar back in place @ the lower a-arms. Using a jack, raise the center of the sway-bar until the frame bushings contact the frame rail. Make reference marks to drill holes for the bushing brackets (center the brackets on the rail & use a center-punch or sharpie to mark the spots for drilling). Drill the bushing bracket holes. Bolt the bar up directly to the frame.
08-30-2011, 10:22 PM | #12 | |
08-30-2011, 10:30 PM | #13 | |
I wouldn't go through the effort for 2" or less spring drop. Over 4" of drop (spindles & springs combined) & it puts things closer to optimum.
08-30-2011, 10:34 PM | #14 | |
08-30-2011, 10:35 PM | #15 |
Sotti, I want to put a rear sway bar on my truck. I can't find a good source. Are there other years or alternatives? How much do they help? Sorry Camshaft not trying to hijack your thread.
08-30-2011, 10:37 PM | #16 |
dude go for it the 88-98 sport trucks had them.. the fronts will work im not sure about the rears
08-30-2011, 10:40 PM | #17 | |
08-30-2011, 10:51 PM | #18 |
I just bought two set of those, same part # for 1in rotors. they are in fact 2.5in drop.
John 82 Chevy Silverado 350ci/TH350 |
08-30-2011, 10:54 PM | #19 | |
I did this the first time on an older pre-73 truck because it didn't have any bracket extensions (it didn't have a sway bar). I thought if the spring drop is around 2-3" & the bracket extension spaces the sway-bar bushings 3" off the frame, not using the spacers should put things back where they were 'intended'. If it didn't work, I wasn't out anything. Since all of my trucks have had @ least 2.5" spindles & 1-coil cut, this mod has worked just fine. I just did it again on my dually. It should have about 5" front drop w/the lower BJ raised in relation to the frame (no cut springs @ this time). I still don't have the drivetrain installed so it's difficult to know the total drop amount but I went ahead & knocked the extension brackets off. Once the truck is back on the ground, I'll look to see where the bar sits & make the final decision. More than likely, it will be directly bolted to the frame.
08-30-2011, 11:17 PM | #20 |
Makes perfect sense to me. I haven't had a clearance issue, but I am careful. I really like the lowered look and the way my truck handles, but I know it can improve. The only thing I don't like is how far I have to bend over to put gas in it. |
08-30-2011, 11:46 PM | #21 | |
The exclusion of the extension brackets was easiest @ the time & the math indicated they weren't needed. To me, the big gain for 'performance' was installing the big HD 1.25" bar & using poly bushings vs. OE rubber.
08-31-2011, 12:00 AM | #22 |
Why do you guys hold the nozzle? I just let it hang and fill on it's own till I hear it gurgle some then I grab it
08-31-2011, 01:12 AM | #23 | |
To fill the original 'bed-side fill' tank in the 74 (w/new inlet & vent hoses) required rotating the nozzle 180° from 'normal' (handle @ the 12:00 position vs 6:00 to get a better shot for less splashing). Holding the gas nozzle basically upside down @ the proper angle required kneeling (the truck has a 6/8 drop).
08-31-2011, 01:35 AM | #24 |
