Old 08-30-2011, 11:48 PM   #1
bloodybigblock
bloodybigblock's Avatar
3" body lift on 89 chevy, what other parts do i need?
1989 chevy 1500 4wd ext cab! I have all mounts and bracket mounts! Where do I get steering linkage and how do I make shifter linkage for my 700r4 trans? Any pointers because I'm doing this myself,thanks guys! I know what to do but unsure of linkage and maybe other small changes I may need to do!
bloodybigblock is offline   Reply With Quote
Old 08-31-2011, 01:49 AM   #2
Mr. 250r
Mr. 250r's Avatar
Re: 3" body lift on 89 chevy, what other parts do i need?
usually when you buy the body lift they give you it, just like a 1-2in piece of metal probably thats how mine i think i got it from summit if not just get a small piece of round metal ace hardware, lowes etc sells them cut make it about 2in long weld or have welded on shift linkage and grind a flat spot like linkage already has and bolt back up pretty easy
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 08-31-2011, 10:27 AM   #3
bloodybigblock
U need 1 for the tranfer case? Its a floor shift! Also what about the steering shaft? Thanks
Old 08-31-2011, 10:49 AM   #4
Mr. 250r
Mr. 250r's Avatar
for some reason i thought it was the old body style but should work about the same but is it 700r4 modified to floor shift or transfer case floor shift if its transfer case it should be fine my truck was, it might sit lower
2003 1500 Silverado
Old 08-31-2011, 02:19 PM   #5
bloodybigblock
Yea mine is transfer case floor shift, my trans shift is still on the column
Old 08-31-2011, 02:33 PM   #6
Mr. 250r
Mr. 250r's Avatar
Well I still think the transfer case would be fine just sit lower in the plastic housing hopefully someone will help you because I never had a body lift on those years my dad has so ill ask him later today
2003 1500 Silverado
Old 09-11-2011, 02:24 AM   #7
brett3xx
well youll need the obvious body bolts and body lifts blocks. Assuming you already have that, youll need you steering extension, Fuel filler extension(dont have to use this on stepside models) bumper brackets, and the automatic shifter linkage extension(its just a 3" long round rod, I think its around 7/16" diameter) Like mentioned earlier you dont have to extend your floor shifter. Youll have to remove the lower portion of your fan shroud if you dont have the spacers to lower it down.
brett3xx is offline   Reply With Quote
