Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-31-2011, 07:33 AM   #1
djracer
djracer's Avatar
From power steering to Manual
What all is needed? Steering Box Drag Link and Pittman Arm?
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-31-2011, 01:47 PM   #2
Super73
Super73's Avatar
Re: From power steering to Manual
Kevin,
My truck when I bought it had power steering on it. It never acted correctly, it would not return straight even after and alignment and a lost of caster. I pulled a box off a 62 and put it on mine with the 62's pitman arm and my existing drag link. Later on I did tie rod ends and ball joints. I found my tie rod ends were from the later 73-82 years (someone put a later disk brake front on).
Not sure this was much help, but thought I would put it out there.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-31-2011, 05:32 PM   #3
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
When I swapped mine I Just changed the box and Pitman arm. Used rest of the parts from the power setup and it steers great. Well as great as a pickup with trick springs and 90/10s on the front can steer, LOL.
Jesse
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
Old 08-31-2011, 09:33 PM   #4
djracer
djracer's Avatar
Thanks Guys!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 09-17-2011, 08:00 PM   #5
68Gold/white
Originally Posted by Super73 View Post
Kevin,
Kevin,
There may have been a problem w/ the particular power box, you had. IF anyone had ever taken the box apart, it's possible the re-assembly wasn't exactly as needed. The spool valve (it's on the input shaft side) is extremely critical to be installed correctly, incorrectly can lead to what your steering box reacted like...
The pitman arm is different when changing types of boxes. AND the flex joint on the input shaft (sometimes called a rag joint) is usually different. The flex joint also has what looks like a thin, narrow, piece of brass shim stock running through it. It is a ground strap the grounds the steering shaft.
68Gold/white is offline   Reply With Quote
