Old 08-31-2011, 02:18 PM   #226
hick
Re: "The Ayatollah of Rusty Hole'a 1987 SWB 6.0 4L80E
Gord,
Who did the sandblasting of your parts for you? It wasn't the same guy that did your frame was it? Mind me asking cost?
hick is offline   Reply With Quote
Old 09-01-2011, 08:00 PM   #227
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Originally Posted by hick View Post
Gord,
It was a welding shop by Barrhead that sandblasted the bed and stuff. Cost about $140 to do it.
1.5 hours work for them at just their shop rate.
Well worth it veres using a wire wheel to try to get it clean enough to paint!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 09-04-2011, 11:19 PM   #228
hick
As usual, thank you sir.
Do you have the name of the shop handy by any chance? Its very hard to find people who will sand blast sheet metal
Old 09-04-2011, 11:27 PM   #229
luifer76
luifer76's Avatar
The 77 looks to be in one piece bro.... nice find.......
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 09-05-2011, 09:40 PM   #230
Gordonr1973
Home Built '87
It was Neeralta Welding. About 20 minutes north of Barrhead. I don't know their phone number off hand & I'm in China right now for work for another week!
Gordon
Old 09-13-2011, 01:52 AM   #231
true74enduro
awsome dash!! im gonna do the samething actually on my 85 i took it up to my guy today i wasnt sure what color i wanted sence mines two tone blue with grey swede interior so i told him surprise me so know seeing yours lets me know what mines gonna be like
true74enduro is offline   Reply With Quote
Old 09-13-2011, 01:54 AM   #232
true74enduro
seeing that por 15 reminds me does anyone ever use there por 15 primer?
Old 09-23-2011, 11:49 AM   #233
Really enjoy your work on this truck.
Palf70Step is online now   Reply With Quote
Old 09-26-2011, 10:41 PM   #234
Gordonr1973
Home Built '87
Well finally some time to do a bit on the truck...
Got the box back together and getting it ready for primer & going through the cab trying to smooth stuff out. More pics later this week.
Slow going!
Bright side is I picked up a better air compressor and a sand blasting cabinet for cleaning bolts and small parts. Got both on sale but the cabinet took a day to put together, darn Chinese picture directions!! ;-)
Gordon
Old 09-29-2011, 12:24 AM   #235
Gordonr1973
Home Built '87
Getting close to priming the truck parts....got to get rid of that surface rust first tomorrow.
Just for the record, this is what I'm using for primer:
1. self-etching on bare metal
2. medium build 2K
3. after block sanding, using the 2K as a sealer
Gordon
Old 10-01-2011, 12:31 PM   #236
Gordonr1973
Home Built '87
Since I had so much surface rust on the roof of my cab I have been focusing on getting it totally prepped and ready for primer this week.
Here it is sanded down and I degreased it last night and let it sit until this morning.
This morning I hit the bare spots with self-etching primer and I will leave it sit for a few hours while I go get some supllies to work on the box later!
Gordon
Old 10-01-2011, 05:25 PM   #237
foamypirate
foamypirate's Avatar
Excellent progress!
foamypirate is offline   Reply With Quote
Old 10-04-2011, 09:46 PM   #238
Gordonr1973
Home Built '87
Got a bit more done today....
For the pop-up gas fillers, I traced & cut out the fillers on sheet metal, cut it to fit, put a crimp around the filler plate so I could weld a nice finish line around it and have room to putty, I chose the location, cut out the box tie down inserts, slotted the hole so I could slide the inserts in, and welded, then mudded them in.
Will insert the fillers after paint though!
Gordon
Old 10-04-2011, 09:47 PM   #239
Gordonr1973
Home Built '87
More...
Gordon
Old 10-04-2011, 09:48 PM   #240
Gordonr1973
Home Built '87
Finished!
No pics about how to weld...enough on the forum here already on that subject!
Note too that you do have the choice to go from the bottom up with the filler through the hole in your insert plate. I didn't though because I wanted a slight lip around the gas hole in case I dropped the fuel hose and I didn't want it to chip the paint easily later on.
Gordon
Old 10-04-2011, 09:50 PM   #241
Pop's C-10
Pop's C-10's Avatar
That is very trick
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 10-04-2011, 09:50 PM   #242
baclay9
Awesome work man
baclay9 is offline   Reply With Quote
Old 10-04-2011, 11:29 PM   #243
Vernski
Very nice work Gordon...Vernski
Vernski is offline   Reply With Quote
Old 10-05-2011, 06:53 AM   #244
73gmc454
73gmc454's Avatar
Wow great idea , those look good in there
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 10-05-2011, 10:15 PM   #245
Gordonr1973
Home Built '87
Thanks guys, still fiddling with them today to get a good fit...
Filled in the tailgate handle too for a flip kit later on.
Gordon
Old 10-09-2011, 09:40 PM   #246
c10bodied26s
Man bro sweet build u got some mad work into this truck keep it up man
c10bodied26s is offline   Reply With Quote
Old 10-15-2011, 01:36 PM   #247
noonzor
nice build! from a fellow edmontonian!
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 11-22-2011, 01:20 AM   #248
Gordonr1973
Home Built '87
Thanks!
Been busy with work lately so haven't been updating the build at all.
I had to change the window regulators, one didn't work and the other one was slow, so thought may as well do them both now.
There are alot of threads about doing this....basically take all the bolts out, unplug the power wires to the motor, spin the motor and the tracks around until you can fish it out.
BEWARE, THE MOTOR AND TRACK HAVE A SPRING ON THEM SO IF YOU DON'T DRILL A HOLE THROUGH THE TRACK AND PUT A PIN IN IT TO KEEP IT FROM SNAPPING OPEN WHEN YUOU TAKE THE MOTOR OFF, IT WILL SPRING APART AND SCARE THE CRAP OUT OF YOU --- PLUS IT COULD TAKE OUT YOUR EYE AND PUT A DENT IN THE SIDE OF YOUR TRUCK!!
One other thing, the bolts they give you with the replacement motors are crap. I drill out the holes a bit and used some bolts I had in the garage. the first pic shows the way I had to wrench them in to get them to fit. I needed to put the 2 bolts in the top of the motor where it sits above the lever mechanism first, then tightened up the 2 bolts that I could reach easy with the wreches...then come back and do the first two.
If you are doing this, you will know what I mean.
Gordon
Old 11-22-2011, 01:30 AM   #249
Gordonr1973
Home Built '87
I then primered the truck. Two coats of 2k to start with everywhere.
I used etching primer on the bare metal bits first though.
Since I was going to cut the jambs, inside the doors, the hinges and all the inside bits first, I concentrated on these parts especially:
- two coats medium build primer
- sand 320 then 400
- etch primer the sanded through spots
- more medium build primer
- more sanding with 400
- sealer coat x 2
Since these are the bits that are not going to be seen as much, I was a little forgiving of runs and dust specs.
Overall the primer turned out well and it will hold fine until I am ready to spray the outside panels.
Gordon
Old 11-22-2011, 01:32 AM   #250
my4by2
my4by2's Avatar
Lookin' good man! Love that filler door mod!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
