Old 08-31-2011, 09:12 PM   #1
aceoutdoor
Replacing fender emblems?
Is it necessary to remove the fender to replace the 10/20 etc emblems on the cab end of the fenders? The back side seems in a tough to access spot. Thanks
aceoutdoor is offline   Reply With Quote
Old 08-31-2011, 09:48 PM   #2
chewychevy67
Re: Replacing fender emblems?
i know on my 67 I had to because you cant get at the nuts to remove them but they may have used speed nuts in the later model years but i can't confirm that. someone will know more im sure.
chewychevy67 is offline   Reply With Quote
Old 08-31-2011, 10:10 PM   #3
aceoutdoor
Yeah I have a 67 also. How long did it take you to replace both emblems chewychevy67?
Old 08-31-2011, 10:23 PM   #4
chewychevy67
to make a long story short i ended up taking the fenders off to replace the emblems and chrome moldings about 4 years ago, then decided to paint and while i had the front end off i rebuilt the engine and im still waiting to put them on.lol. hope this doesn't happens to you (unless you want it to). lol but seriously i think if you take the inner fenders out and loosen the bottom fender bolt you may be able to get them off. just may need a long open end wrench.
Old 08-31-2011, 11:10 PM   #5
71gmcburb
71gmcburb's Avatar
i changed the emblems on my 71 and had to pull the fenders to get to the nuts
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 08-31-2011, 11:25 PM   #6
It's been a while,but as I recall you just need to take most of the inner fender bolts and the lower rear fender mount bolt out. Then you can pull it away enough to get your arm up there. I've never had to completely remove the fender.
Old 09-01-2011, 07:43 AM   #7
hugger6933
That sounds about right. Aman needing to change a fender emblem, ends up in a full frame off resto. It is funny [or sad] how that happens
hugger6933 is offline   Reply With Quote
Old 09-01-2011, 11:38 AM   #8
leddzepp
Moderator
leddzepp's Avatar
a 3/8 gear wrench works best. i did not have to remove anything this way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-01-2011, 12:57 PM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
I have removed lots of emblems and never had to loosen any bolts. Just need a long arm and a long 3/8ths wrench. I am not saying it is easy, but can be done from the bottom.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-02-2011, 07:08 AM   #10
I take a few bolts out to make it easier. Nothing to it and worth the effort,IMO. Maybe my arms are just short Point is,you don't need to remove the fender,which would mean the hood,too.
