Old 08-31-2011, 09:52 PM   #1
racingisnature08
How to fit 35's?
i have an 86 k10. have 31's bfg all terrains waitin to go on once wheels are powdercoated. but have an opportunity to trade for 35x12.50x15 bfg all terrains. plannin on lifting the truck but not til spring when i have time. will the 35's fit if i put on a body lift for now? any help would be great, REALLY dont want to trim anything if i can avoid it
thanks, dan
racingisnature08 is offline   Reply With Quote
Old 08-31-2011, 10:01 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: How to fit 35's?
I am running 35's with a 4 inch suspension lift and they rub the back side if the fender at full lock.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 08-31-2011, 10:15 PM   #3
racingisnature08
the front springs have lost some strength. but i wouldnt be off road with them flexing much at all, just thinkin if i can get them to fit for now ill have them for the lift in spring... might just sell the 31's in spring, theyll still be near new
Old 08-31-2011, 10:18 PM   #4
russgt
russgt's Avatar
If you only drive it on the street and do only mild off roading, you should be alright with a 3-4 inch body lift. If you get into a situation in which you stuff a tire up into the wheelwell, you'll have some pretty hard rubbing. Alot of guys run 35s on 4 inch suspension lifts and have minimal problems.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 08-31-2011, 11:28 PM   #5
85sierraclassic
85sierraclassic's Avatar
lot depends on what wheels your running too
85 GMC sierra classic : 350, 4spd, 205, 3.42s, 35s
85sierraclassic is offline   Reply With Quote
Old 08-31-2011, 11:35 PM   #6
H8PVMNT
I say a 2.5" spring lift with a bit of cutting and some hammer work on the fenderwells. You can always add a 1-1.5" body lift without anyone noticing. Bump stops can be modified a bit and that will help too. Any more body lift than that and guys will think you are a poser .
I've seen a blazer running this setup with 35s and it was unstopable on the trail and completely stable. And remember, if your tires don't rub a little then they aren't big enough!
H8PVMNT is offline   Reply With Quote
Old 09-01-2011, 07:19 PM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
4" suspension lift and mild wheeling should work out great. Don't put them on there until you lift them it will rub real bad and tear up your new rubber. Should look pretty awesome with 35"s and a lift kit though.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
