Old 09-01-2011, 06:43 PM   #1
turbobusa504
hood
Hi, my dad and i are building a 68 c10 from ground up everything is going well except for the hood. the lines are lines up nice its just the rear of the hood. eveytime we open then close the hood the rear of the hood has to be pushed down to line back up with the fenders. these are brand new hinges but are old springs could this be what is kkepin it from going all the way down in the rear? thanks in advance.
turbobusa504 is offline   Reply With Quote
Old 09-01-2011, 09:43 PM   #2
turbobusa504
Re: hood
bump
Old 09-01-2011, 09:51 PM   #3
litew8
litew8's Avatar
Re: hood
Mine does that too! My hinges/springs are original. Haven't really cared to look to see why, so it'd be interesting to see if you find the cause.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 09-01-2011, 11:07 PM   #4
turbobusa504
Re: hood
well if i ifind out i will post. anyone else?
Old 09-02-2011, 12:12 AM   #5
dmack91
dmack91's Avatar
Re: hood
I loosened the hinge bolts and pushed the hood up as far as it would go. While holding it there, I retightened the bolts. Seemed to cure most of the issue.
Not my idea, I read it somewhere originally.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 09-02-2011, 01:01 AM   #6
heeroyue2002
fat old dude
heeroyue2002's Avatar
Re: hood
my friends truck does the same!
1972 c-10 shortbed 350/400
build thread http://67-72chevytrucks.com/vboard/s...d.php?t=389157
1968 workhorse http://67-72chevytrucks.com/vboard/s...d.php?t=446216
Accepting part donations
heeroyue2002 is offline   Reply With Quote
Old 09-02-2011, 01:52 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Re: hood
This is your solution.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-02-2011, 03:01 PM   #8
JORGIE95961
Re: hood
i loosened the hinge bolts and pushed the hood up as far as it would go. While holding it there, i retightened the bolts. Seemed to cure most of the issue.
Not my idea, i read it somewhere originally.
x2 it works
JORGIE95961 is offline   Reply With Quote
Old 09-02-2011, 03:07 PM   #9
67chevemall
67chevemall's Avatar
Re: hood
X 3 Mine drove my crazy always having to push the hood down everytime. Had a nieghbour body guy fix it for me. Now I have to take the hidge off to get the heater core out and I am nervous I'll mess it up again.lol
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 09-02-2011, 03:59 PM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
Re: hood
Me i rather have a hinge problem instead of being cold
stsalvage is offline   Reply With Quote
Old 09-02-2011, 08:17 PM   #11
slikside
slikside's Avatar
Re: hood
Ditto! The timing of this thread is incredible....just looking at this the other day.
This part seems counter-intuitive to me. I was thinking about moving the hinges, but pushing it all DOWN since the problem is that the hood is too HIGH in the rear.
I must be wrong though, cuz 3 or 4 of yuz have done just like dmack91. Can someone explain how this is so??
slikside is offline   Reply With Quote
Old 09-02-2011, 08:19 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Re: hood
By loosening the rear bolts on the hinges you are pushing the back of the hood down when you raise the front and push past the "stopping point"
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-02-2011, 09:09 PM   #13
turbobusa504
Re: hood
okay it worked perfect. thanks for the help i see i wasnt the only one who was having this problem.
1 raise hood and loosen the three hinge bolts to the fender.
2 push the hood up in the center as high as possible toward the celing.
3 while holding upward pressure have someone tighten the bolts.
THANKS GUYS.
Old 09-02-2011, 09:39 PM   #14
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: hood
Drill two small holes(one at each end of the hinge)all the way thru the hinge and mounting area.Makle them just big enough for the bit or a small nail to go thru.Remove the hinge and do what you need to,then when you put it back just use the pins to align it.Then tighten it down right back where it was.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-02-2011, 10:11 PM   #15
slikside
slikside's Avatar
Re: hood
Understood. Thanks leddzepp!
THANKS GUYS.
Cool. Thanks for the 1,2,3!
Old 09-02-2011, 10:15 PM   #16
slikside
slikside's Avatar
Re: hood
Or, you could just closly trace the outline of it before you remove it.
Or, loosen up/drop the back part of the inner fender well....I went this route because it was easier to do solo.
