Old 09-04-2011, 11:43 AM   #1
RPBurris
RPBurris's Avatar
DIY cab/bed bushings/mounts??
My 69 is sitting on a 79 chassis. The PO has a mix of steel pipe and whatever else he could find to mount the cab on the mounts. I want to replace the cab mounts,bed mounts, rad support mounts but not sure if any kit will work because of the modifications. Has anyone had success fabricating their own bushings of any kind? I have heard of old schoolers using hockey pucks but not sure if this is a valid option. Thanks.
1969 Chevy K20 Longbed
RPBurris is offline   Reply With Quote
Old 09-04-2011, 01:27 PM   #2
snj8198
snj8198's Avatar
Re: DIY cab/bed bushings/mounts??
I've done hockey puck body lifts in the past grafting car bodies on blazer chassis. I'd drill the centers and install a hardened insert through the stack. Still they were kinda sketchy. I never made any other bushings though. I wonder how and where a guy could get the material for them? Bet it wont be cheap. I'll search around online a bit over coffee.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 09-06-2011, 01:16 AM   #3
Mr. 250r
Mr. 250r's Avatar
I would stray very far away from the hockey puck idea I've also seen wood block as a block lift lol some people just think of the weirdest things to get a lift
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 09-06-2011, 11:03 AM   #4
RPBurris
RPBurris's Avatar
So it sounds like no miracle cures readily exist. Maybe i will just try my luck at a kit and see how everything goes together.
Old 09-06-2011, 11:46 AM   #5
Mr. 250r
Mr. 250r's Avatar
Im not exactly sure what you mean I don't think but are you talking about like a body lift being the spacers in between the body and frame or something else
2003 1500 Silverado
Old 09-06-2011, 12:21 PM   #6
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
If you check out my 71 build thread, I think towards the end I was working on body mounts and bushings. I got a bushing kit for the 71 truck and made my mounts with the right sized hole to fit the bushings. I've heard the hockey pucks work great, for a little while, but they're not made to hold the weight of a truck and will enventually break under the stress. Probably not the safest decision to use them...
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 09-06-2011, 12:59 PM   #7
Redcap
There are places you can buy raw polyurethane bushing stock to make your own bushings..
Redcap is offline   Reply With Quote
Old 09-06-2011, 06:23 PM   #8
RPBurris
RPBurris's Avatar
I think this is what i am thinking of. http://www.jegs.com/p/Energy-Suspens...42834/10002/-1
I dont see how to adjust it though if necessary.
This is what i currently have. The radiator support looked stock.
Old 09-07-2011, 04:43 AM   #9
propanemudtruck
wow.
-Kevin
Old 09-07-2011, 05:57 PM   #10
RPBurris
RPBurris's Avatar
Originally Posted by propanemudtruck View Post
wow.
And that is the good side!!
