Old 09-04-2011, 02:29 PM   #1
into69z
"brand new second-hand"
into69z's Avatar
Did 69 c-20's come with a manual throttle?
Still putting together a dash for my truck and I wanted to find out if the option was available for a manual throttle control for the 69? Any one have pictures of the dash and the "hook-up" on the engine side? If available, did they use a 67-68 bezel? and did it change the wire harness?.................whew, that's a ton of questions
Steve
69 3/4t custom camper
tilt,am/fm,speed warning,air gauge,buddy buckets,aux battery, big block,p/s,p/b,a/c
67 Camaro
96 Impala ss-sold
04 hybrid Honda-saving gas for the blue truck!:
b69:
into69z is offline   Reply With Quote
Old 09-04-2011, 03:13 PM   #2
Steve Hafner
Steve Hafner's Avatar
Re: Did 69 c-20's come with a manual throttle?
Below is a picture of someone's 69 C-20 with a manual throttle and another picture of a glove box SPID from a 69 396 Longhorn.
It could have come from the factory ( I have a few pictures of SPIDS with the manual throttle listed ) or it could have been dealer installed too.
I also have pictures saved of them on BOTH sides of the steering column ( from the factory and the dealer )
Steve Hafner is offline   Reply With Quote
Old 09-04-2011, 06:17 PM   #3
71 super
71 super's Avatar
From what I have seen the 67-68 were on passenger side, the 69-70 were on the driver side and 71-72 were on passenger side? The 67-8 is understandable due to location of the wiper and lights, but when they went to opposite sides things went out the window. My guess is the way the system operates. The 71-72 system actually has a seperate lever welded to the gas pedal that the cable mounts to the 69-70 and guessing 7-8 used a cable or chain that mounted in engine compartment. My 72 has factory manual throttle and is mounted on passenger side under wiper switch, which is the same for all that I have seen, the difference shows up in the lever located on the inside pedal - some are seperate lever some are a tab welded to exsisting lever.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-04-2011, 07:37 PM   #4
into69z
into69z's Avatar
Thanks for the info......I guess the "cable" on a 69 then, mounts on the drivers side and snakes around to come out of the firewall in line for the throttle rod, so they can be tied together. Anyone have pictures of where the cable comes thru the firewall and how/what connects it to the carb?
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 09-05-2011, 02:47 PM   #5
into69z
into69z's Avatar
anyone have pictures of where the cable bracket mounts on the throttle rod and how it hooks to the carb?
Steve
67 Camaro
96 Impala ss-sold
b69:
Old 09-05-2011, 03:54 PM   #6
john
member #16
john's Avatar
look at this thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=182074
john is offline   Reply With Quote
Old 09-05-2011, 05:47 PM   #7
into69z
into69z's Avatar
Originally Posted by john View Post
Thanks John-that help's a lot.
Anyone else have install pictures-Thanks
Steve
67 Camaro
96 Impala ss-sold
b69:
