Old 09-04-2011, 09:21 PM   #26
jocko
jocko's Avatar
Re: power DRUM brake conversion (with a dual master cylinder)
Good point fleet - after all the yammering (mine), it might be worth while to list the (my) lessons learned...
If you want to convert from non-power single reservoir master cylinder DRUM/DRUM (i.e. stock for most cases) to Power Boosted dual reservoir master cylinder DRUM/DRUM, here's the gouge:
1) Recommend buy the booster and master cylinder TOGETHER (or take them from another vehicle "together" so you know you have a compatible system) for a "Power Drum/Drum" setup. (ensures compatibility. I found that MOST vendors (oreily, autozone, etc) do not list a separate part number for power vs manual master cylinder by itself. My mistake was to buy a 67 C10 DRUM/DRUM master cylinder and 75 impala booster separtately - turns out the master is a MANUAL DRUM/DRUM master and you need a POWER DRUM/DRUM master. The way to tell is that a MANUAL DRUM/DRUM master will have a deep hole in the master's piston to accept about 1.5+" of the brake pedal pushrod. A POWER DRUM/DRUM master will have a very shallow indent in the back of the master's piston to properly mate up to a booster. Specific recommentation - buy CaptFab's bracket and a 67 C10 master/booster combo. All you'll need to do is open the holes on the bracket very slightly. IF you can find a POWER drum/drum master for a 67 C10 for example BY ITSELF - then good on you, I could not and the parts store zit squad wasn't any help either. Unless it comes puking out of their computer, they barely even know their own names (my apologies to any member counter jockeys - if you're on this forum, you obviously don't fit that category and I wish you worked at my Oreily's...)
2) a DRUM/DRUM master cyl will have equal size reservoirs - not as common as the uneven reservoir'ed disk/drum masters.
3) Confirm you have at least 15-16" vacuum before going down this road. Much less and I'd just get manual brakes so you needn't worry about it.
4) Confirm you actually have a fitting to hook power brakes to on the intake manifold. Or at least the plugged vacuum port so you can add the fitting. It SHOULD be located right over the #8 intake runner on the manifold in front of and slightly to the passenger side of the distributor. If you don't have one, some have said you can tee in to the pvc line from under the carb. In my case that no workie because I'm going to a dual quad setup and I don't think it'd fit even if I did tap the un-drilled boss on the manifold.
5) pedal ratio - For MANUAL: 6to1 / For POWER: 4to1. Talkin mechanical advantage here - i.e. pedal ratio = (distance from pedal pivot to the point on the pedal where the pushrod is connected) / (overall distance from the pivot to the center of the brake pedal). So, in other words, even if you do everything correctly in converting from manual to power, the basic brake pedal setup of your old manual brakes is technically incorrect. Personally I would not change the pedal ratio, messy business that - just be aware of it and realize you probably have close to 6:1 vice 4:1 so transitioning to power brakes will REALLY seem effective because you will still have the manual brake mechanical advantage (which is greater than what it should be for power brakes).
6) In most cases, you'll need to modify the connection between the booster and the current brake pedal push rod. Most boosters you buy will have an eyelet on the end where it WOULD have connected to a bell crank mechanism. Hack it off and make a home-made connection to your existing brake pedal pushrod. Helps to design a little adjustability into the design so you can tweak it.
I'm sure I'm missing something. But that's obviously nothing new....
Old 09-05-2011, 01:00 AM   #27
Captainfab
60-66 Nut
I did not find a specific power brake master cylinder on O'Reilly's website either. However I did find one on Napa's website.
https://www.napaonline.com/Catalog/C...306735472&An=0
I know you have decided to stay with manual brakes Jocko, but this is for the others that may read this thread, just so they know that master cylinder is available. I will be contacting my local O'Reilly's on Tuesday, to find out if they can find a power brake master cylinder. I deal with the men and women in the comercial department, and they know how to look in the 'book' if they need to.
Old 09-05-2011, 01:10 AM   #28
jocko
jocko's Avatar
Thanks Captain, much appreciated. No worries at all - appreciate you posting for others to find this master. Looking at the pic of the back of the mc shows exactly what I would have needed for this to work with a booster. For others - the same view of a manual master cyl would show about a 1.5+" deep hole in the back of that piston.
I would still go with power were it not for the fact that the dual quad manifold would probably preclude it - just doesn't seem to be room for a fitting and the distrib to stuff a fitting in between the two (there is an undrilled boss, but very little room). If for some reason I don't go with that manifold in the future or if, once I get it all together I can find out for sure if there is room, I can still go power and I'm only out the cost of power mc, about $15 (so I'm gonna hang onto your bracket). OReily's did take my booster back, God bless em, even though it'd been many months since I bought it - they seemed to take a "little" sympathy on me for being on crutches when I bought it.
So, going for a quick fix for now - may still go power someday depending on how the build progresses, but at least know what I'm in for and know how to do it now.
This has been a very enlightening weekend!
Old 09-05-2011, 01:45 AM   #29
Rich 5150 69
Rich 5150 69's Avatar
Hey Jocko we`re not done yet.... you can still use the 67 master and split your lines, just in manual mode, it will give a bit more safety.....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
