Old 09-05-2011, 01:26 PM   #1
68350
68350's Avatar
Puzzled?
I have a 1970 402 in my shortbox. It has a stock quadrajet that was rebuilt, 65-67 396 heads, basically stock. It will start up fine if I don't start it for a few hours, but as soon as it runs for 20 minutes, it'll die and will not restart unless it sits for a while. Anybody have any ideas? thanks
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 09-05-2011, 01:29 PM   #2
BMERDOC
BMERDOC's Avatar
Re: Puzzled?
There seems to be a run on vapor lock and fuel starvation on the forum for a coupla days.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 09-05-2011, 01:33 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Re: Puzzled?
When you shut it down take the breather off and look down the throat of the carb with a flashlight to see if it's leaking fuel into the manifold. It usually takes a while for the fuel to evaporate off after you shut it down and that may be the reason it won't start right away.
Some quadrajets have leaking plugs and if they weren't sealed or sealed properly they may be leaking.
68gmsee is offline   Reply With Quote
Old 09-05-2011, 02:06 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
Re: Puzzled?
Try using starting fluid and see if it starts with it. If it does, you have a fuel delivery problem. If not, its electrical - like ignition module, coil, etc...
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 09-05-2011, 02:15 PM   #5
OJ1988
Just a car guy
OJ1988's Avatar
Re: Puzzled?
When you try and restart it, what does it do? Does it crank?
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 09-05-2011, 02:16 PM   #6
71swb4x4
71swb4x4's Avatar
Re: Puzzled?
Just to clarify it is dieing after running for 20 minutes correct?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-05-2011, 02:50 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Re: Puzzled?
hmmm, I missed that part. If it dies on it's own, something else could be causing it. As mentioned above it could be ignition related.
It's still possible that flooding could cause it to die, but it wouldn't necessarily be at 20 minute intervals and you would notice that by blackish smoke coming out of the exhaust.
The 20 minutes may be about the time the engine reaches maximum temperature even though mine does it in about 10 minutes or so.
Maybe the coil???
Old 09-05-2011, 05:27 PM   #8
68350
68350's Avatar
Re: Puzzled?
it has hei, it dies on its own after 10-20 minutes. It will crank all day after it dies, just wont restart. I did check to see fuel is still getting to the carb after it died, and fuel is still getting there.
Old 09-05-2011, 05:31 PM   #9
71swb4x4
71swb4x4's Avatar
Re: Puzzled?
Have you checked the HEI module? Maybe the module is going out and the heat of the engine is affecting it.
Old 09-05-2011, 05:45 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Re: Puzzled?
Take a plug cable off, place close to block and see if it shoots a spark. Sometimes it's hard to see so if you have a bolt or similar insert it in the boot first then have someone crank it.
If it doesn't spark, then it's something in the distributor. Cap, rotor, module, coil.
Old 09-05-2011, 09:25 PM   #11
hjewell2
hjewell2's Avatar
Re: Puzzled?
Yes siree I had that happen to me once back in 1992 out in the middle of nothing. damm thing just stopped then got it started about hour later then stopped ten mins later. Got a ride home dropped in a HEI I had setting in a box started right up and made trip home. The ducks were safe that day never made it to hunting ground.
hjewell2 is offline   Reply With Quote
Old 09-06-2011, 12:33 AM   #12
68350
68350's Avatar
Re: Puzzled?
Ok, i will check the hei out, because it was in the motor when I bought it.
Old 09-06-2011, 04:56 AM   #13
Re: Puzzled?
It does sound like the module. A characteristic of a failing module is it cuts off when it gets warm,then works once cooled back down...for a while.
