Old 09-05-2011, 07:25 PM   #1
bsccp
5.3 motor mounts?
Finally got around to dropping in the 5.3 this weekend. Still had the stock mounts on it from the 01' Suburban it came out of.
For those of you that have used the 5.3 what have you found to be the easiest combo of LS block mounts and frame plates? It looks like about a 12" x 5" piece of 3/8 plate trimmed down to clear the upper control arm and then welded in place?
Don't want to go with a solid mount but have seen the Trans Dapt, etc kits that might allow for a bolt on with some adjustment? Planning on running A/C but right now it looks like I will be running a high mount system since the truck bracket is right on top of the upper a arm!
bsccp is offline   Reply With Quote
Old 09-05-2011, 09:32 PM   #2
bsccp
Talking Re: 5.3 motor mounts?
Clarification: 5.3 into a S10 frame with the 51 GMC sheetmetal
Old 09-05-2011, 10:30 PM   #3
BlueJeep
BlueJeep's Avatar
I think I'm either going to use the car shop poly bushing ones or just the basic adapter plates and old style sbc mounts.
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
86 Suburban lowered 4/6
54 Chevy wagon
49 Chevy/s10 mix
88 Jeep Wrangler rockcrawler
BlueJeep is offline   Reply With Quote
Old 09-06-2011, 10:51 PM   #4
BlueJeep
BlueJeep's Avatar
Here's the ones I'll likely be using:
http://carshop.carshopinc.com/produc..._id/86960/2350
build threads:
86 Suburban
88 Jeep 6.0 swap
49 Chevy truck
54 Chevy wagon
54 Chevy wagon
49 Chevy/s10 mix
Old 09-07-2011, 01:57 PM   #5
JML55
JML55's Avatar
Check this link from my thread , i used adapter plate old style Chevy mount and camaro frame bracket. My frame has a camaro clip, I'm not sure what the s10 crossmember looks like but it may be similar.
http://67-72chevytrucks.com/vboard/s...2&postcount=83
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
