Old 09-06-2011, 01:16 AM   #1
05crewcab
05crewcab's Avatar
Carbureted starting procedure
Hi guys,
I don't think my truck starts like it is supposed to. Here are the rough procedures depending on when I am starting it:
After sitting 10 hours to 10 days: Pump pedal once and it fires right up
After sitting for 5-10 minutes and warm: No pump, fires right up
After sitting for more than 10 minutes and less than 10 hours: Hold the pedal down while cranking and then it fires up.
The last part concerns me. I would think I should have to pump it once or twice to get it to start and not have to hold the pedal down. The engine is a 350. Edelbrock 1406 carb (with a 1" riser). HEI ignition. FWIW, I have a clear fuel filter and after it sits a while there is no fuel in the filter. Normal?
Anyone have any ideas and or how do you start your trucks? Maybe I am just crazy...
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 09-06-2011, 02:51 AM   #2
dmack91
dmack91's Avatar
Re: Carbureted starting procedure
The first 2 sound normal.
On the last, have you tried starting without holding it open (I assume you did)? Mine will generally start in that circumstance with just feathering the gas.
If you are having to hold it to the floor to start, it is usually flooding.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 09-06-2011, 03:00 AM   #3
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
electric choke or man.
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 09-06-2011, 09:59 AM   #4
05crewcab
05crewcab's Avatar
Electric choke
1971 C-20 350/350
Old 09-06-2011, 09:59 AM   #5
Tink
Tink's Avatar
We have a clear fuel filter and the fuel drains out of it when it sits...
I agree the first two are pretty normal... to start my 76 when it sits for a few hours it does not need a full pump of fuel, but it does need something, so I'm with dmack91, I just feather the gas a bit until it gets going.
BTW, is that your bulldog? Cool dog.
69 Chevy C10
88 Sierra
02 2500 Suburban
And too many S10s to list!
Tink is offline   Reply With Quote
Old 09-06-2011, 10:32 AM   #6
05crewcab
05crewcab's Avatar
Thanks, the bulldog's name is Winston. He's a 60lb chunk of fury
I guess I don't hold the pedal to the floor, but I do more than feather it....i'd say turn the key and half throttle until it starts(usually within a second or two) This is my first vehicle with a carb, so I don't really know what's right or wrong.
1971 C-20 350/350
Old 09-06-2011, 11:32 AM   #7
MacGyver72
MacGyver72's Avatar
Based on your last post all three conditions seem normal. If you read the owner's manual, it will instruct you to start a warm engine with the gas pedal halfway down. A carb allows fuel to evaporate so you don't get a shot of fuel to the cylinders immediately like on a fuel injected engine. The amount of evaporation depends on how long it sits.
MacGyver72 is offline   Reply With Quote
Old 09-06-2011, 11:40 AM   #8
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
The key phrase is "it fires right up". There can be different factors that come into play. This could also change as fall and winter start to creep in. Bottom line is "if it aint broke....". Probably best to leave it alone. You start messing with it an you might cause it to become tempermental in one or more of those areas. Then you spend a ton of time, sweat and hair trying to get it back to square one.
prostreetC-10 is offline   Reply With Quote
Old 09-06-2011, 05:15 PM   #9
67Slider
67Slider's Avatar
I have the same configuration and mine fires exactly the same as yours.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 09-06-2011, 06:13 PM   #10
05crewcab
05crewcab's Avatar
So it sounds like I am crazy... Thanks for for the input guys!
1971 C-20 350/350
Old 09-06-2011, 06:30 PM   #11
lil hoodlum
lil hoodlum's Avatar
I hate to say this, I have the same exact set up as you but I almost never have to give any gas (i.e., pump the pedal) to start mine. Maybe it has something to do with location, I'm in Texas, and altitude.
My glass filter seems to be about half-full when it has been sitting for awhile.
Don't know what else to say, it would be interesting to see what else others have to say about their start up procedure.
Good luck!
Keith
lil hoodlum is offline   Reply With Quote
