09-06-2011, 12:22 PM | #1 |
Junior Member
What lug nuts are u running on ur Coys?
Bought some used wheels for the burb and did not get lug nuts.
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
09-06-2011, 01:53 PM | #2 |
Re: What lug nuts are u running on ur Coys?
Are those the black chrome or does it just look like that in the pic?
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
09-06-2011, 02:09 PM | #3 |
Junior Member
it is the pic they are regular chrome
09-06-2011, 03:55 PM | #4 |
I used regular mag wheels lug nuts I can take a picture for you tonight to give you an idea.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
09-06-2011, 04:29 PM | #5 |
Junior Member
Thanks for the offer big al. I have some coys on my other truck that is not finished that I can steal a lug nut off of to take to the parts store.
09-06-2011, 04:38 PM | #6 |
pretty sure they are 7/16 - 20.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
09-06-2011, 04:43 PM | #7 |
Junior Member
The holes look to be very narrow and does not look like all styles of lug nuts will work.
09-06-2011, 04:55 PM | #8 |
Look familiar?
Standard auto parts chrome lugnuts.
03-22-2017, 02:55 PM | #9 |
Does anyone know the exact lugs for these coy wheels? thanks!
03-22-2017, 08:04 PM | #10 |
Active Member
If that is a 5 on 5 bolt pattern 5-127mm then it is 1/2 lugs ..... 6 lug and and I no some guys are running 5- 4 3/4 are 7/16. If the lug holes have a smaller diameter hole then you need to use what they call a socket lug they will work on everything using a bulge seat. . I worked at one of the nation's largest retailer selling tires for 33 years. Doug
03-22-2017, 08:11 PM | #11 |
Active Member
Here is what the socket lugs look like.
03-23-2017, 10:23 AM | #12 |
^^^^Listen to this man^^^^^^
I run the same lugs on my Coys. |
03-23-2017, 11:42 AM | #13 |
Old member
1/2" 20 what I used on my Boss 338's. The 2 rear wheels I have 1/4" spacers so I got 2 sets of the deep thread lugs for them to get more thread engagement. Same basic wheels as far as lugnuts go.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
