![]() Join Date: Jun 2011
70 cab frame mounts
Are the frame mounts for the cab the same on 2wd and 4wd frames ??
Junior Member
Re: 70 cab frame mounts
No, the frame mounts on the 4x4 are thicker.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Fabricate till you "puke"
To add a little to that, the 3/4 ton 2wd, & the 4x4's have a taller rear cushion...the 1/2 ton 2wd's have the short rear cushion under the cab. My guess ,is that you are looking for the frame brackets? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Yes i am looking for the steel brackets that are riveted to the frame for a c10 4x4
I think you should also be able to use the brackets, from a 3/4ton 2wd, as the rear cushions are the same as your 4x4. Maybe one of the 4x4 guys will jump in to confirm this.....anyway,BTT. crazyL
